Rose Rolls - The unathorized Compass Rose autobiography
Re: Rose Rolls - The unathorized Compass Rose autobiography
Postby 2bits » Thu Jun 29, 2023 11:31 pm
Nice updates!! Man she looks for for a new camper I was wondering if you were still camping in it!
Thomas
2bits
2bit Member
Postby Sparksalot » Fri Jun 30, 2023 2:11 pm
2bits wrote:Nice updates!! Man she looks for for a new camper I was wondering if you were still camping in it!
Thanks! She’s still hanging in there. My dad was stunned when I mentioned she’s 15. I think he expected a lot less lifespan.
Sparksalot
Images: 687
Postby Sparksalot » Fri Jun 30, 2023 2:13 pm
@2bits last month in Big Bend.
172098
172099
172101
172100
Sparksalot
Images: 687
Postby 2bits » Fri Jun 30, 2023 2:28 pm
Great shots!! I especially like the last one with the sunset/sunrise.
Thomas
2bits
2bit Member
Postby Sparksalot » Tue Jul 18, 2023 8:33 pm
I had an extra awning so figured why not. I have shade throughout the day now.
172211
So where does Mollie hang out?
172210
Sparksalot
Images: 687
Postby Sparksalot » Thu Jul 27, 2023 10:26 pm
First blowout ever. Bummer.
172241
Sparksalot
Images: 687
Postby 2bits » Thu Jul 27, 2023 10:28 pm
Ouch! that really slung up some GOOP! Glad you were able to pull it over no problem though!
Thomas
2bits
2bit Member
Postby Sparksalot » Fri Jul 28, 2023 9:17 pm
2bits wrote:Ouch! that really slung up some GOOP! Glad you were able to pull it over no problem though!
That entire road was a muddy mess. I had to drive a way to safely change it on firm ground.
Sparksalot
Images: 687
Postby Sparksalot » Sat Jul 29, 2023 8:55 pm
Rose got her feet wet. Again. This time in Wyoming leaving Walk The Winds 23.
172246
Sparksalot
Images: 687
Postby Sparksalot » Sat Jul 29, 2023 9:01 pm
I never started the trip log I meant to, so don’t have exact numbers. I estimate Rose has around 40,000 miles on the clock.
Sparksalot
Images: 687
Postby Sparksalot » Mon Sep 25, 2023 10:53 pm
Like most vehicle projects, it’s never just a simple matter to swap something.
I only wanted some tougher tires. But no, the smallest 14” all terrain tire is 27”. The ones I had that keep getting rock cuts, were just under 25”. Eh, no biggie, I actually had clearance under the fender.
but not the lip.
172458
I could have done some spacers to slide it out a bit. A friend mentioned blocks at the spring perches to lift. Yeahbut, the axle was on top. It’s also crowned so no flipping it like I originally intended. But I started looking anyway.
Viola, Dexter makes an accessory to do the under-over conversion. It’s bolt in, but recommended to tack weld it after installation.
Before. That’s only the spring perch with the notch.
172459
And after.
172460
Before and after, with the frame level in both. The new tires give an inch of lift. The axle flip gives 4“.
172098
172462
Looks like someone skipped leg day.
172461
Sparksalot
Images: 687
Postby Sparksalot » Mon Oct 09, 2023 8:33 pm
Did the first trip with the new tire and axle configuration. The tires are over 2” taller, plus moving the axle below the springs again, gave a meager 5” of lift. It pulled well though.
172526
The 100# hound appreciates the shade.
172527
Sparksalot
Images: 687
