The Astroliner
Re: The Astroliner
Postby OP827 » Wed Sep 16, 2015 11:01 pm
Atomic77 wrote:I was going to say you are speaking my language KC... But then you said dingle balls.
But you've definitely got the right idea going on!
Maybe click here for Atomic Age design lines inspiration... :twisted:
OP827
Images: 414
Re: The Astroliner
Postby Atomic77 » Thu Sep 17, 2015 10:44 pm
Definitely inspiring! Thanks Op!
Michael
"The Strength is in the Sum of the Parts..."
The Astroliner
Follow The Astroliner Blog Here!
Check out our YouTube video
Atomic77
Images: 309
Re: The Astroliner
Postby McGuffin » Sat Sep 19, 2015 7:06 pm
Hi Michael,
Maybe that should have been "Jingle Bells"? I would definately go with them all the way - especially since we're getting close to Christmas :)
Larry
McGuffin
Images: 211
Finally... Progress!!!
Postby Atomic77 » Sat Oct 17, 2015 10:46 pm
I finally had a Saturday that I could drive down to get the Astroliner out of storage. Finally! It's pretty fun pulling it down the road... It tows like a dream. I got it back to my brothers shop and after a long summer the build resumes! My focus today was the rear taillight/license plate area. I ground down the seams and made a slight recessed area where the carbon fiber will lay. I mixed up some epoxy thickened with aerosill to fill the gap. Then I cut the carbon and wet everything out. Pretty simple lay up with two layers. When it goes off I'll knock it down with 40 then 80 grit and a little filler and it will be all molded in. Next, I'll do the same on all the edge seams. Not a lot done, but at least I'm back in the game!
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Vedette » Sat Oct 17, 2015 11:24 pm
Good to hear! :thumbsup:
I hope to be back on mine in about 2 weeks???? :worship:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: The Astroliner
Postby dales133 » Sat Oct 17, 2015 11:43 pm
Good to see you back at it mate
dales133
Re: The Astroliner
Postby OP827 » Sun Oct 18, 2015 2:26 am
I can not recall seeing anyone doing carbon fiber on a trailer...cool! :thumbsup: Good to see you back in the build.
Now I am thinking where I can use some carbon on mine! ;)
OP827
Images: 414
Re: The Astroliner
Postby Atomic77 » Sun Oct 18, 2015 10:50 am
Not really necessary, but I have it on hand so thought I would use it in place of glass. It's a superior product so I know the seams will be strong and permanent.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby noseoil » Sun Oct 18, 2015 5:12 pm
Michael, looks like you're getting into it again now. Can't wait to see the progress shots. Welcome back!
137905
noseoil
Images: 670
Re: The Astroliner
Postby Atomic77 » Sun Oct 18, 2015 9:21 pm
Thanks guys. I didn't get a lot done, but she's out of storage and ready to go. Next weekend we'll do more glass/carbon fiber work and try to get some body work done. There will be a lot of filling and sanding which is all time consuming but I've got all winter now.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Atomic77 » Sat Oct 24, 2015 8:56 pm
Saturday update: Today was a good day for the Astroliner. Carrie and I spent the morning grinding a recessed area to accommodate the carbon fiber that would cover the seams. By the end of the day today we had all the carbon fiber laid up and all of the remaining seams glassed-in. All the glass work is now complete and ready to be sanded and prepped for filler. Getting this done is a huge step in the right direction. I've attached some pictures, even though this "rough-in" stage isn't very pretty! But trust me, it will be sooner or later.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby dales133 » Sat Oct 24, 2015 9:51 pm
Nice micheal, right back into it!
dales133
Re: The Astroliner
Postby OP827 » Sat Oct 24, 2015 11:00 pm
This is really great, with such reinforcements it will be as strong as steel in the corners and still light! :thumbsup: I am really impressed by your ability to glass quite a sharp (1/4" or 1/2" radius maybe?) corner and especially with carbon fiber, we all know here that you have skills, but yet how did you manage to do such sharp seam corner with stubborn carbon?
My hat's off to you my friend :applause: .
OP827
Images: 414
Re: The Astroliner
Postby tony.latham » Sun Oct 25, 2015 12:10 am
Yeah, how'd ya do it? :thinking: It looks biased cut, but the carbon I've played with was stiff.
Re: The Astroliner
Postby Atomic77 » Sun Oct 25, 2015 9:42 am
Tony is correct, laying it up on a 45 degree bias helps considerably. Unfortunately with the curve and angle it can have a mind of its own for sure. It takes patience and practice and having a couple extra hands helps as well.
It's not as pretty as I would like but as pretty as it's going to get, considering the level of difficulty. Once it's sanded and a light filler applied it will no longer matter. And thanks OP, the corners are definitely strong! But the main thing for me is, no trim mouldings and no screw holes! Like my brother says, we could always flip it over and float it like a boat!
:eyebrows2:
Michael
The Astroliner
Atomic77
Images: 309
