Well it's official. ZooZooBee build. 4/27/11: Done !
Postby tcolar » Fri Sep 17, 2010 3:09 pm
8/14/2010 -8/17/2010: Continued work on large inside features before I put the roof on.
Finished building the framing for the kids bed platform / seat / storage
Built a "counter" with a location for the sink, can use to eat (using stools) or as a desk.
View from back:
Views from front:
Kids in "sleeping"position :)
Still have to build the smaller front storage that will include the electrical center.
tcolar
Images: 15
Postby vtx1029 » Fri Sep 17, 2010 10:53 pm
Looking good, but where does the big people sleep?
vtx1029
Images: 70
Postby tcolar » Fri Sep 17, 2010 11:08 pm
That's what all the empty floor space is for :)
tcolar
Images: 15
Postby tcolar » Mon Sep 27, 2010 12:02 am
Electrical cabinet / front storage:
Tested with the battery too (tested the inverter) .. did blow the fuses the first time :(
tcolar
Images: 15
Postby tcolar » Mon Sep 27, 2010 12:03 am
Applied some primer & paint:
tcolar
Images: 15
Postby tcolar » Mon Sep 27, 2010 12:06 am
Installed the front radius indoor skin
Using lots of pressure and some screws (through temporary 2x1) to pull it against the ribs.
Epoxy was applied to the ribs.
tcolar
Images: 15
Postby tcolar » Mon Sep 27, 2010 12:09 am
Took advantage of some nice weather to take it out.
Installed the roof and back ribs:
Hey look, now I have a clue what it's gonna look like !
Son checking out the roof vent opening:
tcolar
Images: 15
Postby tcolar » Mon Sep 27, 2010 12:12 am
It's getting dark in there so installed a temp. shore power inlet and wired all the lights:
Installed the back radius inside skin: (had one panel snap - pressed to hard)
All but last inside panel to be installed:
tcolar
Images: 15
Postby J.Heyboer » Mon Sep 27, 2010 12:04 pm
Looking good,
I like the bunks, they look just right....
John
J.Heyboer
Images: 84
Postby tcolar » Mon Oct 04, 2010 2:29 pm
Spent some more time working on the inside skin.
Worked quite a lot on the electrical, making sure it's all good before I close it up.
Installed the insulation:
tcolar
Images: 15
Postby tcolar » Sun Nov 14, 2010 6:55 pm
Have been working slowly lately, because i've been busy and it won't be ready useful spring anyway.
I've worked on the exterior skins - don't have much pictures as camera was missing at the time.
lack of pics, but I used straps and screwed 2x1 across while epoxy was setting.
Then I sanded all the edges and any not completely flush areas:
tcolar
Images: 15
Postby tcolar » Sun Nov 14, 2010 6:59 pm
I sealed all screw holes and other gaps:
Then made some wheel well covers:
Next steps:
Build a door and then "paint" the exterior.
tcolar
Images: 15
Postby tcolar » Thu Mar 10, 2011 12:08 pm
Update 3/10/11
Haven't updated this in a long while.
I didn't do too much during the winter as I was quite busy and it was just a bit too cold in the garage.
I've mostly worked on finishing the interior but also finished the exterior preps (ready to paint), built the door, mounted the wheel wells and worked on the battery box/platform.
I need to take some better pictures, but here a a few for now (with a lot of mess)
What's left (expected to be done in next few weeks)
- cpes / uniflex "paint" on the outside (was waiting on warmer temps)
- Mount door /window / fan / raindrips
- Mount lights / License plate
- Finish mounting battery box
- Finish hooking up water / hand pump faucet
Expected Maiden Voyage on March 23rd
tcolar
Images: 15
Postby tcolar » Mon Mar 14, 2011 4:34 pm
3/11/11: I've worked on the bedding:
Kids mattresses are foam pads from Fred Meyers.
I bought some sealy sheets for cheap (employee price at outlet store) and made "cases" for them.
For the grown-up mattresses I bought a Foam mattress from Ikea (SULTAN FLORVAG) and cut it to size (It's VERY comfy)
It's already "wrapped" in a plush cover, so I reused that for making the case after cutting.
tcolar
Images: 15
Postby tcolar » Mon Mar 14, 2011 4:38 pm
3/12/11: Final sanding and CPES:
I've sanded(fine) the exterior one last time:
Then cleaned up:
Then applied 2+ coats of CPES:
tcolar
Images: 15
