"Hypno-Toad's Command Post." Door and windows in!
Re: "Hypno-Toad's Command Post." Wall profiles cut!
Postby jeff0520 » Sun Jul 22, 2012 5:03 pm
Made some progress today. I made two of the multipiece spars. I used a protractor to measure the angle, then divided the angle in half. I set my table saw to cut the angle, and ripped two pieces and glued them together. The spars came out pretty good:
95747
I still have 3 multipiece spars to do yet, but I pretty much have the hang of doing them now. Should be no big deal :D
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Postby cracker39 » Mon Jul 23, 2012 12:24 pm
jeff0520 wrote:Made some progress today. I made two of the miltipiece spars. I used a protractor to measure the angle, then divided the angle in half. I set my table saw to cut the angle, and ripped two pieces and glued them together. The spars came out pretty good:
I'm happy that you got those spars right the first time. I did some hard thinking to come up with the correct way to do it. Once you've done one and have the procedure down, the others are easy to do. It was my belief that making them in two parts, then joining them, would reduce the chances of the lumber warping.
Dale
cracker39
Images: 233
Re: "Hypno-Toad's Command Post." Wall framing begun!
Postby jeff0520 » Sun Aug 05, 2012 4:10 pm
I cut and installed the very firse piece of wall framing today.
96415
This piece runs from the nose of the trailer to the wheel well. I also started cutting the next piece working counter clockwise around the profile. I'm going to do all the edge framing first, the the seams between the sheets on both sides, then I'll start framing in the doors windows and all the rest.
jeff0520
Images: 128
Postby jeff0520 » Mon Aug 06, 2012 7:40 pm
I'm on jury duty this week, so I'll be home in the evenings. Time to make some things happen out in the build shop! :twisted:
96540
96539
Edge framing layout continues. Here I'm using the stub ends I cut off of spars to mark, cut, and dry fit my spar notches. Things are beginning to move along nicely :D
jeff0520
Images: 128
Re: "Hypno-Toad's Command Post." Wall framing in progress
Postby jeff0520 » Tue Aug 07, 2012 6:26 pm
This week of jury duty is really translating into a lot of progress on the Command Post. I installed the next 2 edge framing pieces.
96589
96588
I also used a flush trim bit in a router to shave the next framing piece to follow the curve of the profile. Just clamp it into place, and let the router follow the profile. Pretty sweet way to do the tricky bit.
96587
96586
Just waiting on some glue to dry, and for me to cool off a bit. It's still august in Alabama :D
jeff0520
Images: 128
Re: "Hypno-Toad's Command Post." Door and window planning
Postby jeff0520 » Tue Aug 14, 2012 5:26 pm
Hello everybody.
My truck will be out of the shop tomorrow, so I guess I'll have to go back to earning a living instead of building every day. :thumbdown:
I did get quite a bit done though. I have all the edge framing done for the left wall, and all the frame pieces cut for the right wall. Framing the right wall will go a lot quicker since the frame pieces are precut. I also started laying out door and window locations. :D
96792
96791
96790
96789
jeff0520
Images: 128
Postby jbyrd » Wed Aug 15, 2012 5:27 am
coming along nicely. Just curious as to where you got that door at? I really like the big window in it!
Til later, See ya
Jeremy
My build journal #1 "SOLD" : viewtopic.php?t=45945
my build journal #2 "SOLD": viewtopic.php?f=50&t=59216
jbyrd
Images: 172
Postby jeff0520 » Wed Aug 15, 2012 7:31 am
jbyrd wrote:coming along nicely. Just curious as to where you got that door at? I really like the big window in it!
I got it on ebay. Here's a link to the seller http://stores.ebay.com/BARGAIN-CONVERTERS-and-ELECTRONICS There was a problem with the purchase though. The box ripped open in transit.The door arrived a little banged up, and missing the window screen, but the seller made it right by refunding half the price. I ended up getting the door for $60. I have a little straightening to do on it, but for that price, I'm not bitching.
jeff0520
Images: 128
Postby jbyrd » Thu Aug 16, 2012 5:50 am
Wow that was a great price on that door most of the doors I thought were a deal have been in the 100 buck range and they didnt have a window in it.
Til later, See ya
Jeremy
jbyrd
Images: 172
Postby jeff0520 » Thu Aug 16, 2012 8:13 am
Yeah, Original price was $120, and they refunded half when it showed up banged up and missing the screen. For that kind of savings, I'll straighten a little bent aluminum :D
jeff0520
Images: 128
Postby jeff0520 » Sun Sep 23, 2012 4:35 pm
FINALLY got back out to the build shop to work on the trailer. It's been a crazy couple of months :(
Completed a window frame, and the final sheet to sheet seam on the skin. I'm going to go put a few more pieces in before I call it a day. At least there's finally some progress
jeff0520
Images: 128
Postby jeff0520 » Mon Oct 22, 2012 8:03 pm
Well, The framing is done for the left wall profile. I've started adding the countersunk screws to reenforce the glue holding the framing to the skin. Once the screws are in, I can install radius blocks in the window frame, and cut out the opening :)
99068
Sorry the pictures are so dark. I worked past sundown today :)
99067
99066
jeff0520
Images: 128
Re: "Hypno-Toad's Command Post." Left wall COMPLETE
Postby jeff0520 » Thu Oct 25, 2012 7:23 pm
Completely finished left wall today :D
99123
99124
99125
99126
jeff0520
Images: 128
Postby jeff0520 » Thu Oct 25, 2012 10:10 pm
I have realized I have a problem. I thought I'd build the Command Post in the portable garage tent, but the camper is going to be WAY too tall. I'm thinking I can extend the legs of the portable garage, and get the extra 3 feet of height I need. Anyone have any experiance with that?
jeff0520
Images: 128
Postby KCStudly » Fri Oct 26, 2012 9:40 pm
I had a portable garage for a time. I got it with the optional extended height. Each of the hoops received an extra piece swedged to fit in the bottoms of the main hoops, had provisions to attach the rail along the bottoms, and for the diagonal bracing, too. Of course, the tarp and doors (end curtains) were sewn longer to suit, as well.
I would attempt to contact the OEM and see if they have an option package that you can buy. Depending on your climate, keeping your existing tarp/canvas with an open air bottom could actually be a benefit, allowing good ventilation while still maintaining a roof over your head.
Next option would be to build knee walls along both sides, say out of 2x6's, tie them together across the bottom with 2x4's so that they can't topple over, and anchor the whole ten assembly on top of them. Use pressure treated for the bottom sill of the knee walls for a temporary solution.
More permanent solution? Dig two trenches down a bit, level, tamp gravel, and build up CMU block knee walls to set your tent garage upon.
I always regretted not laying a good gravel base (over a sand covered moisture barrier) under my temp carport. The ground moisture was drawn up by the solar effect on the tent and I think the gravel base would have helped prevent this.
$.02
