by noseoil » Thu Jun 04, 2015 7:57 am
Tom, sorry this one didn't work for you, but you learned a lot about materials & their use in builds! I have to say congratulations on a job well done & a great design concept, even if it didn't go as you wanted it. I think you are on the right track with the plywood.
I used 3/4" plywood (about 19mm) for my frame, the skeleton, and 3mm for the inside & outside skins on my build. It isn't finished yet, but this seems to be a good way to build and works for everyone who uses it, so I figured I was safe with this method. Here in Tucson I have similar concerns about the temperature. While in the winter it seldom gets to -6c, it does go up to 45c, which means the surface of something in the sun is much hotter, about a 50 degreec change during the year. Inside a car it can get up to 66c on a hot day in the summer. I'm not worried about the wood & expansion, as long as the glue is good there will be no problems with this type of build.
I know weight is a concern to you on your build, so you might consider using 3mm birch plywood on the inside, & just a thin aluminum skin on the outside. If the aluminum is glued in place with a marine adhesive on the framework, it will stay forever, look good & not have any problems with heat or moisture. In the states here we have access to 0.025" aluminum material (about 0.5mm) which would be strong enough & light enough for a small trailer. See if you can find something like that to use.
Best of luck & I really like your design concept!
