My new trailer build
Re: My new trailer build
Postby Mushin » Tue Feb 23, 2016 11:12 pm
pchast wrote:Well Done!!!!!!!! :thumbsup:
Thx! Was really fun to build, not officially done (probably never will be).
Got a front rack to build, small odds n ends on the inside, some work in the galley.....
Mushin
Postby jkidd6339 » Wed Feb 24, 2016 12:51 am
After a few times out camping you'll probably have a list of changes. I wish mine was done I want to go camping.
jkidd6339
Postby Mushin » Wed Feb 24, 2016 5:48 pm
That is how my last trailer was, never stopped working on it!
Trial run this weekend tho!
Mushin
Postby fourbtgait » Sat Feb 27, 2016 4:22 pm
I like your FJ and trailer. Imagine both go well offroad.
fourbtgait
Images: 16
Postby Mushin » Sun Feb 28, 2016 3:42 pm
fourbtgait wrote:I like your FJ and trailer. Imagine both go well offroad.
Thx, found out this weekend how well it does!
Mushin
Postby Mushin » Sun Feb 28, 2016 3:43 pm
Made a rack for the tongue, put a bunch of "necessities" on it and drove off.
Took her for a shake down run this weekend. Was fantastic! Towed great, followed me everywhere I went!
Next stop Utah....
Mushin
Postby roamer » Sun Feb 28, 2016 4:59 pm
Good to hear it all went well.
I like the exterior treatment! :thumbsup:
Dave
If you think you can't, you won't
138765
roamer
Images: 25
Postby lfhoward » Sun Feb 28, 2016 5:28 pm
Looks fantastic with the mud on it, and with the cargo platform on the tongue as well. Sweet trailer!
Do you know about how much it weighs now that it is finished and fully loaded?
lfhoward
Postby Mushin » Sun Feb 28, 2016 6:12 pm
With all my must have camping essentials, she weighed in at just over 1790. That's with 2 5 gallon jerry cans full on the front and 2 5 gallon water cans full in the back. I won't be carrying these full all the time, but for Utah I will be so I wanted to know.
Thanks for the kind words everybody, so much better to climb in and go to sleep then setting up a RTT!
Mushin
Postby Mushin » Sat Mar 05, 2016 8:46 pm
Does anyone have an answer to how much distance/clearance is needed between frame and tire?
I was running 15 inch Jeep rims with 225/75/15 and had about 1 1/2 inches of clearance and on issues on trail. I just mounted 31x10.5 x 15 on the same Jeep rim and now have 1 inch of clearance.
Jeep rims have 5 1/4 backspacing so I can buy new rims with 4 1/4 backspacing pretty cheep, but don't wanna spend the $ if I don't need to.
Thx
Mushin
Postby pchast » Sat Mar 05, 2016 9:39 pm
What is th e greatest movement that you expect from the suspension.
Personally I'd add at least 1/2" to that specification. :thinking:
pchast
Images: 97
Postby Mushin » Sat Mar 05, 2016 11:12 pm
You mean up and down movement? That's like 4 inches of travel. No way I need 4 1/2 of clearance! Maybe we are talking about 2 different measurements
Mushin
Postby jmascioni » Sun Mar 06, 2016 1:10 am
I think your trailer looks cool! I have just started the design stages for mine and I was looking at doing a similar design to what you have. I am starting with the 5x8 frame as well, since the wheelbase tracks almost perfectly behind my 87 Wrangler.
I was wondering what you used for the aluminum trim around the outer dimension of the walls? Is that just a section of aluminum angle?
I wouldn't think that you need more than the 1" of clearance to the sidewall of the trailer, the suspension that you have cycles up and down, it doesn't have much for a side-to-side movement due to the leaf springs. If you were to run a low pressure in your tires, then I could see the sidewalls getting close. Or if the tires got into sticky mud, its possible to get a build up in there with the minimal clearance.
My trailer build is going to be riding on 33x12.5x15's that were previously on the Jeep but were replaced by 35's. And ultimately saved for the trailer. I have been looking for the wheels to match my clearance issues.
jmascioni
Postby Mushin » Sun Mar 06, 2016 3:53 pm
jmascioni wrote:I think your trailer looks cool! I have just started the design stages for mine and I was looking at doing a similar design to what you have. I am starting with the 5x8 frame as well, since the wheelbase tracks almost perfectly behind my 87 Wrangler.
Thx alot! It's just 3/4 angle I got from mc master carr.
Found some cheapo 15" rims on 4 wheel parts for 40 bucks each and 3.75 backspace so that buys me at least 1 inch more of clearance so about 2 inches total so problem solved!
Mushin
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
