The trailer was getting a little heavy for me to move around so I decided to go ahead and replace the foot of my weld-on tongue jack with a large wheel to make things a little easier. Curt makes this one that fits the standard 2” jack so it was a easy swap, just cut off the foot and drill 2 holes to fit on the replacement.
Another thing I had been meaning to do was to finish riveting the aluminum flashing around the AC unit penetrations. The VHB tape I used to initially secure it was probably fine, but I felt better on these knowing that it was permanently secured. While I was doing this, I also added some clear tubing to the two condensate drains coming from the unit to make sure that the condensate was being released below the base of the trailer.
And then on to some of the water system work. I had initially planned to put the pump and the expansion tank into the area beneath the sink in the galley, but decided to save some space and minimize the chance of a major leak by placing these items below the trailer. This will allow for the only water to be inside the trailer are tubes directly going to the water heater, sink, and the shower. This harbor freight pelican case knock off was a nearly perfect fit for the city water connection, the 12v water pump, and the expansion tank. The outlet of the expansion tank will go up into the trailer and branch off to the 3 appliances.
Finally, I got a couple more pieces of the exterior wall assembled. I started with the very front, which was tricky because it angled away from the trailer around 8 degrees, and all 4 sides had to be cut with the saw at an angle to allow the pieces to line up right.
After that piece was installed, I moved on to the side that had the wall and slowly worked my way down to the correct dimension until there was a tight fit. This piece took a while to cut out because the two sides were cut at a 30 degree angle on the saw, and were also angles on the piece itself which made cutting things a bit tedious.
And with that installed the angles of the camper are starting to take shape and it’s easier to picture the interior space.
