Lady Bug Winter Warrior - finally campable!
Postby starleen2 » Sat Apr 11, 2009 10:21 am
Mike - it is 76" wide - I'm pushing the 80" rule! the Last build was 74 inches wide. We will sleep crosswise on a queen sized foam mattress.
SmokeyBob - It is the thickness of the plywood - plus the internal bracing of the walls. The lateral 90 degree bracing of the lower wall joints add additional stiffness to the entire perimeter of the floor - thus guarding against any twisting or sagging - now this only works to a certain distance - after 16 inches of overhang :thinking: - more bracing is needed underneath. What you see is 13 1/2 inches of overhang. This overhang worked out very well for the last two builds with no apparent sagging and was very stiff.
Now off to finish those walls ;)
starleen2
5th Teardrop Club
Postby starleen2 » Tue Apr 14, 2009 10:03 pm
Whew – got a lot done today. Those lessons about bending plywood paid off today as I got the first curved piece installed. Cindy and I heeded all the advice and put our collective strength together and viola – curving piece of ply. We have some temporary stringers across until I can install the permanent ones. The walls have the additional framing to prevent any warping and are insulated with the Blue Styrofoam ¾ insulation. Also the windows are framed out to be installed later – these will be flush mount to the exterior
Framing details
152139
152143
152140
Walls and Front panel attached along with window cutouts.
152144
152145
152146
152147
starleen2
5th Teardrop Club
Postby aggie79 » Wed Apr 15, 2009 9:12 am
:applause: :thumbsup: Looking great! Keep things going!
Postby campingdude » Wed Apr 15, 2009 6:38 pm
WOW Scott, Looking Good :thumbsup: :thumbsup:
David
campingdude
Twelve Grand Club
Twelve Grand Club
Postby starleen2 » Wed Apr 15, 2009 8:20 pm
Put the top inner panel on today. While it is only 36 " long - It was a booger to bend - But we got it on. Also completed the wheel well boxes. Got the straps on and letting it all bend into shape.
starleen2
5th Teardrop Club
Postby starleen2 » Sat Apr 18, 2009 8:28 am
Rain Day – sure glad I’m working in the garage today
Size Comparison Mock Up
152151
With Mrs Starleen (5’00”)
152149
With Me(6’00” ) – the hatch is actually 3 inches tall than I am-, however due to the camera angle – It looks shorter
152150
Here is a side view with the window cut outs and wheel wells installed
152148
Finished front and wheel wells installed
152156
Almost finished with the lower portion. Each day brings more progress
starleen2
5th Teardrop Club
Postby toypusher » Sat Apr 18, 2009 8:34 am
You're really moving along there, Scott! :thumbsup:
It's looking good and I can hardly wait to see it finished!
toypusher
Images: 324
Postby RAYVILLIAN » Sun Apr 19, 2009 7:06 am
Looks great guy you'll be camping in that before you know it. :lol:
Gary
111961Image
RAYVILLIAN
Images: 109
Postby SmokeyBob » Sun Apr 19, 2009 10:24 am
Scott
Any idea on what the rear section will weigh? Will you use any devices to assist in the lifting?
Pics for Building the Alegria I
To view video click Here
Bob & Judith
SmokeyBob
Images: 161
Postby starleen2 » Tue Apr 21, 2009 8:01 pm
SmokeyBob wrote:Scott
Haven't got that far yet. I'm still getting the lower portion finished. Over the weekend, we added the front panels over the spars and leveled the seams. I sprayed the interior today with some clear polyurethane sealer - I'm going for the natural wood interior look - I need to sand out some of the Runs - but overall it finished out nicely. Almost ready to install the flooring and the bed. Then I can start work on the hatch ;)
starleen2
5th Teardrop Club
Postby mikeschn » Wed Apr 22, 2009 3:47 am
Looking good there Scott. :)
Postby starleen2 » Wed Apr 22, 2009 9:06 am
A few more picts for your picture hungry folks
From this:
152156
To this:
152157
What a difference a coat of polyurethane makes (actually four coats)
And the front is coming along nicely! tried to do it in one piece but I have a compound curve on the front (bow in the center) so I had to use individual strips. Sanding, sanding, sanding. . . .
152158
Now for some trim and flooring – stay tuned
starleen2
5th Teardrop Club
Postby Dark Horse » Wed Apr 22, 2009 10:07 pm
:thumbsup: Looks Great!
I like anything that turns money into noise.
Dark Horse
Postby starleen2 » Thu Apr 23, 2009 8:26 am
Took out the scales and decided to do a weight check using the three points method on the lower section. (the scales only go up to 300lbs) Right wheel + left wheel+ Tongue Jack=570lbs
starleen2
5th Teardrop Club
Postby Miriam C. » Thu Apr 23, 2009 3:26 pm
starleen2 wrote:Took out the scales and decided to do a weight check using the three points method on the lower section. (the scales only go up to 300lbs) Right wheel + left wheel+ Tongue Jack=570lbs
:o That sounds like you are on a great track. Is the 3-way real accurate? I am too lazy to take mine to a scale. :oops:
Looking forward to seeing this in person. 8) :thumbsup:
Users browsing this forum: azgreg and 17 guests
