225's Teardrop!!!
Re: 225's Teardrop!!!
Postby wlivesey » Sat Mar 30, 2013 6:18 am
Looking good! Seeing your frame build has given me the itch to build another...
wlivesey
Images: 283
Postby 225 » Sat Mar 30, 2013 9:25 pm
Thanks!
Floor is built, epoxied, and siliconed! Tomorrow, I will put bed liner on, the off to the walls!
Postby 225 » Sun Mar 31, 2013 1:30 pm
Tube of silicone says it may take up to 7 days to dry. Which is no biggie because I am going on a motorcycle trip for a week next week anyway.
Better pics of almost finished trailer:
Profile and holes cut. I still need to cut the notch for the hatch, which I will do later today.
Postby 225 » Mon Apr 01, 2013 1:43 pm
The silicone dried up faster than I thought it would. So today, I cut the notch for the hatch on the walls. Then laid down epoxy, then bed liner on the bottom.
I also I put the bed liner on the bottom of the floor. So I am going to let everything cure for the night. And in the morning, I'll place everything on the trailer, and start on the cabinets.
Postby 225 » Thu Apr 04, 2013 7:24 pm
Sorry for the lack of updates over the last couple of days. But the camper shell is done. Wiring is done. And I am working on the cabinets, and hatch tomorrow. Should have the A/C in too. I am waiting on tan bed liner and more epoxy to come it before she will be done. Other than that, the galley is all I have left.
I'll be 99% done other than waiting on bed liner to come in to coat the outside, and she'll be finished.
Carpet on the wall on the window side. Painting the ceiling.
Door side:
More tomorrow!!
Postby KCStudly » Thu Apr 04, 2013 8:26 pm
Your enthusiasm is great! And the progress is awesome! :thumbsup:
"Other than that..." they are never really done. :roll:
Postby rmef27 » Fri Apr 05, 2013 2:20 am
your build looks great so far,I need to start mine soon.
rmef27
Postby AlgoDan » Fri Apr 05, 2013 5:21 am
Hey 225 your trailer is coming along,looking good. A quick question, I see you installed your door did you use weather stripping on the inside trim. Also what did you use for outside door seal..
[quote="225"]Sorry for the lack of updates over the last couple of days. But the camper shell is done. Wiring is done. And I am working on the cabinets, and hatch tomorrow. Should have the A/C in too. I am waiting on tan bed liner and more epoxy to come it before she will be done. Other than that, the galley is all I have left.
Door side:
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby 225 » Fri Apr 05, 2013 8:05 am
The door has a rubber gasket on the outside. Though, it's not that great of one. I am planning on mounting the door with the trim ring, then using that black RV sealant and going around the edge with.
Postby AlgoDan » Fri Apr 05, 2013 8:19 am
Thanks 225, I am using butyl tape under the windows/door outside. I have the same door with the rubber gasket but have read butyl tape also is the way to go. I will also do a bead of sealant when all is done.Cheers :thumbsup:
225 wrote:The door has a rubber gasket on the outside. Though, it's not that great of one. I am planning on mounting the door with the trim ring, then using that black RV sealant and going around the edge with.
Build Journal
AlgoDan
Images: 238
Postby 225 » Fri Apr 12, 2013 8:04 pm
I have done some of the cabinets, and worked on the hatch. Not real happy with the hatch. Gonna redo it.
Postby AlgoDan » Sat Apr 13, 2013 5:22 am
The hatch can be a beast. I knew that the hatch was going to be time consuming and precise. So take your time with it and good luck..your moving right along. :thumbsup:
225 wrote:I have done some of the cabinets, and worked on the hatch. Not real happy with the hatch. Gonna redo it.
Build Journal
AlgoDan
Images: 238
Postby RandyG » Sat Apr 13, 2013 8:39 pm
I like the way the AC fits in the galley like that. Are you sure you wanna leave the hatch open in order to run it? Maybe you could put a small door right behind the AC built into the hatch so you can close the hatch and open the door. Sorry, I tend to complicate things.
Randy
RandyG
Images: 115
Postby rmef27 » Sat Apr 13, 2013 11:26 pm
I was wondering about the ac having to have the rear hatch open as well.it would work great to put a vented panel right there too so you can keep it closed if you wanted too.just throwing it out there.its looking great man keep it up.
rmef27
Postby Junkboy999 » Sat Apr 13, 2013 11:56 pm
I know you got your hatch mostly built but what about something like this. Small door on AC side, bigger
door on the Left side. The left door is also a table support like the Sunhopper build. I'm thinking about this
style door so I can just access my cooler without opening the whole hatch.
104655
check out the Sunhopper back doors/tables
page 5 had the pictures fourth post down.
Junkboy999
Images: 52
