GuyllFyre Alpha 2 - 5' Wide
Re: GuyllFyre Alpha 1
Postby GuyllFyre » Wed Apr 17, 2013 5:58 pm
Removed the edge molding, caulked all the extra holes, gave everything a scuffing with a scotch brite, wiped it down and put a coat of primer on it.
Then started tearing into the trailer and mocking up the new suspension.
Things I have for sale on craigslist:
http://albany.craigslist.org/search/?ar ... catAbb=sss
Things I have for sale on eBay:
http://www.ebay.com/sch/merchant/seansmith
GuyllFyre
Postby GuyllFyre » Sun Apr 21, 2013 3:45 pm
Didn't do anything Saturday, slept and rested.
Today I got moving at a reasonable hour, got drill bits, bolts, and more caulk and adhesives.
Got the suspension done on the trailer. Axle isn't perfect but it'll have to do for now.
Got the new wheels on it, drilled holes for bolting it down, and got a coat of gloss enamel on it.
GuyllFyre
Postby AlgoDan » Sun Apr 21, 2013 8:13 pm
Looks like it wont be long before you smell the campfire, moving right along. :thumbsup:
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby GuyllFyre » Sun Apr 28, 2013 2:04 pm
Crunchtime is on!
Waiting for paint, glue, and caulk to dry is hella annoying.
Still, got the hatch pretty much ready, same for the door, painted them both today.
Got edge molding on all the exposed edges, not as pretty as I'd like but I'm in a hurry.
Framed in the door, screwed up on the frame but it will do for now, needs to be done and it'll work.
Fenders are on, not perfect but pretty good, think I'm going to get some mud flaps for it.
GuyllFyre
Postby KCStudly » Sun Apr 28, 2013 2:36 pm
Not bad for slam bam. :thumbsup:
Postby GuyllFyre » Fri May 03, 2013 6:04 pm
Definitely need to get a new axle and flip it above the springs.
Futon mattress is a little big but will do for now.
Ready for maiden voyage!
GuyllFyre
Postby KCStudly » Fri May 03, 2013 7:33 pm
I apologize for not looking back over your whole thread, but you do have some form of ventilation built in, right?
Air Tight Teardrops can KILL You
I don't see any windows or roof vent; did I miss something?
Just checking.
Postby GuyllFyre » Fri May 03, 2013 7:49 pm
I have a roof vent installed. Didn't have time to get a window in like I wanted but definitely have a vent installed.
GuyllFyre
Postby KCStudly » Fri May 03, 2013 7:53 pm
Cool. :phew:
Postby PKCSPT » Fri May 03, 2013 11:21 pm
:applause: very nicely done
121172 116946 159644
PKCSPT
Images: 61
Postby AlgoDan » Sat May 04, 2013 5:26 am
Nice job, load her up and go smell the campfire now... :thumbsup:
Build Journal
AlgoDan
Images: 238
Postby GuyllFyre » Sat May 04, 2013 8:26 am
Thanks guys!
Shakedown run went well, no issues.
Now to cruise!
GuyllFyre
Postby GuyllFyre » Fri Jul 26, 2013 3:38 pm
Alpha 1 can be considered a success!
Towing on the highway was no issues, my car towed with no problems, kept up with traffic, and could even pass with it!
Only took about 5 minutes to set up and level and was so nice to have a mattress and blankets and be able to stretch out and camp, be warm, and not have to worry about it.
Next up, a 5 wide and no hatch. I don't need the storage or the galley outside, so I can use the space as inside storage instead.
It will also be easier to keep leaks to a minimum. The tailgate wasn't finished and leaked and the OSB swelled at the edges a little but still, this was a perfect quick build!
Alpha 1 is officially for sale.
GuyllFyre
Postby GuyllFyre » Tue Apr 29, 2014 6:56 pm
This one is being built in a hurry.
I've got until Friday to make this camp-able.
The rain isn't helping and I've got too many projects in the garage and canopy to fully fit it in but I've got the deck built and the sides cut out and did a nice and neat job with the jig to router the radii clean.
I need to do some quick patching and sealing, most likely with undercoating spray or whatever I can get cheaply.
Ordered the edging today, will be available for pickup Thursday. Hoping to have the sides up, spars in, and FRP laid in place.
The lumber I picked up was cheap and horrible, the design I chose made it show it's weaknesses.
I spent a good day repairing those issues and making the base usable.
Today I was hoping to have the sides both cut out and the FRP glued on but the rain made me hustle to get the radii cut, put it under cover, put a fan on it, and get it dried back out for the FRP.
GuyllFyre
Re: GuyllFyre Alpha 2 - 5' Wide
Postby Junkboy999 » Wed Apr 30, 2014 12:08 am
GuyllFyre wrote:This one is being built in a hurry.
Wow, Friday. some people work well under pressure. I take things slow. takes me an hour just to thinking about getting out of bed.
I glad Alpha 1 turn out ok. Can’t wait till friday to see A2.. :thumbsup:
Junkboy999
Images: 52
