by Shar » Fri May 09, 2014 12:57 pm
Another go at fixing the electrical issues today. I called the manufacturer of the new connector we bought, and they said it was 100% safe (for the tv) to connect the 4 wired connector to the 5 wires from the trailer. They said to connect the 2 brown wires to the 1 brown wire with a marette. This is what we had done the last 2 times, we just weren't sure it was right.
So, just like last time, the left brake lights worked, but not the right ones, or the amber running lights on the side. We decided to open up the amber lights and examine them. It turned out that the light bulb is connected to a piece of metal with a hole in the end. When you install the light, you are supposed to slide that piece of metal out of the light casing, so that the mounting screw can go through it, thus pressing it against the trailer frame and allowing the light to ground. This was not in the instructions, but once we did it the 2 running lights worked, and we were ecstatic! First good news in a week!
We still have no idea why the right brake light isn't working. We tested the bulb, and the light itself, and they both worked. We've checked all the connecting points along the route. Could there be something wrong with the wire itself? I plan to buy some sort of meter to check if power is running through the wires or not. I now understand why some people buy these trailers and throw the stock lights away!
Here is my cranky baby, tucked under a tarp at the back fence. It's raining again, and time to go to work.
- Attachments
- trailer under cover.JPG (81.67 KiB) Viewed 1380 times
Sheryl
