With the windows now on hand..
Beautiful out today. So got an early start on TD. worked on it til late..
I had changed the radius on the very back of the walls. Had to splice in a piece of plywood. Like the new shape better.. Gives more room for cabinets..
This is the passenger side.. started laying out the window placement.
so I can figure out where to cut them, the door, and the holes for the insulation.. will try to get them all cut Sunday..
We'll have to see how the day goes.
How I plan on mounting walls to floor and trailer:
Holes all laid out for insulation and windows..
Started cutting the holes for insulation first...
Then moved right along to cutting and fitting the windows..
Routing the door using a makeshift jig, 1/4" straight router bit and template guide..
Now it's starting to look more like it may be a tear drop soon....
Will set this side down on other one and use it for a pattern for all the holes, except for the windows..
