Indiana Rambler
Re: Indiana Rambler
Postby Capebuild » Wed Mar 30, 2022 4:37 pm
Ditto what others have said. Really nice job!
I've enjoyed looking at your craftsmanship. Nice!
Capebuild
Images: 130
Re: Indiana Rambler
Postby Indiana Rambler » Thu Mar 31, 2022 3:51 am
Thank you guys very much! I definitely value your comments and ideas on this forum! You’ve all been a great help.
Indiana Rambler
Re: Indiana Rambler
Postby Indiana Rambler » Sat Apr 09, 2022 8:22 pm
Was able to get the rear galley drawer faces on today Image
Need to adjust the drawers a bit, (not my forte) lol. Image
And put the outer skin on the hatch and used mock hinges to check fitment. Opens and closes great, I think I hugged the hatch before I opened it and said nice things to it!
Indiana Rambler
Re: Indiana Rambler
Postby Staryder61 » Sun Apr 10, 2022 11:38 am
:thumbsup: On the galley drawer fronts. looks great..
So a little TLC for the hatch worked. :applause: those hugs and kind words to that hatch did come in handy :roll:
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Re: Indiana Rambler
Postby Indiana Rambler » Mon May 09, 2022 8:05 pm
Not much to post as we’ve been tinkering with little things like wiring the trailer up again, running water lines, labeling the electrical, etc. I’m waiting on the solar cables to install the right side roof panels, which should be in this week. I started installing the left side and all went well. Until, the curve. I knew better and should’ve kerfed the bottom side but was over excited (good way of saying stupidly dumb). I think I’ll get some of that fiber stranded bondo to build up the curve before the final aluminum skin goes on. I can build it up (need 3/8 of an inch in one spot). Doesn’t seem to need structure under there, just to keep the curve asthetic. The curve is fine on the outside perimeter, but in the center section it’s a bit flat. This is the outside profile between the two spars that it’s suppose to be.Image
Indiana Rambler
Re: Indiana Rambler
Postby Staryder61 » Mon May 09, 2022 10:06 pm
Sorry, but from the picture, can't tell what curve this is. Maybe a couple more pics from a little distance.
Or better description might help.
Stay safe, David
Our CTC 6' X 12'
Staryder61
Images: 550
Re: Indiana Rambler
Postby Indiana Rambler » Sun May 15, 2022 1:33 pm
That’s as good as the hump gets. It’ll get covered in aluminum. Plus I ran out of bondo.
Indiana Rambler
Re: Indiana Rambler
Postby JasenC » Sun May 15, 2022 6:57 pm
Looking great.
I really like the proportions you have there, reminds me of a lowered customized old hotrod like an early 50's Buick Roadmaster.
Low and wide 8)
I'll be done when I'm finished, if that's not fast enough, take a number.
Build Thread https://www.tnttt.com/viewtopic.php?f=50&t=74269
JasenC
Images: 122
Re: Indiana Rambler
Postby Indiana Rambler » Mon May 16, 2022 9:19 am
JasenC wrote:Looking great.
Low and wide 8)
Why thank you JasenC.
Indiana Rambler
Re: Indiana Rambler
Postby Indiana Rambler » Mon May 16, 2022 6:29 pm
One hatch? Here we go again.
Indiana Rambler
Indiana Rambler
Postby Indiana Rambler » Thu May 26, 2022 3:23 pm
85 percent done with the tongue box. Not sure what to do for the hinge yet. Waiting on a few more parts and fill some gaps. Just need to put some finishing touches on it.
Indiana Rambler
Re: Indiana Rambler
Postby Indiana Rambler » Tue May 31, 2022 2:22 pm
Received the sides today! Hopefully putting them on this week! Image
Indiana Rambler
Re: Indiana Rambler
Postby Indiana Rambler » Mon Jun 06, 2022 5:46 pm
Made some progress over the last few days. Image
Ended up using the rubber cement method, but it didn’t quite stick everywhere. Figure half float have stick, either one is right or both are wrong. Image
Installed the door to hold aluminum in place to finish cutting the profile. Image
I wanted a roll of ally for the roof, which I can find that is 103 inches wide and (x) amount of dollars per foot. Found a cheaper place in Chicago, but shipping was about as much as the product. And yes, .040 too. So I decided to go the cheaper route and lay panels across each other. Image
This was Sunday evening. Got hatch skinned and trimmed, the hurricane hinge on. Next I was on to the tongue box ally cladding Image
Tongue box on and nearly complete. Just have to finish the curvy trim pieces. Need to mill about an 1/8 off the lip. Then I can install. Just wanted to get the box on and start running the electrical. Waiting on Amazon to show up with more parts. Image
Here’s a good look at the rear. I need to make some sort of spacer for the underside of the hatch and skin it. It looks unfinished. I normally wouldn’t worry about it, but it looks god awful and when the hatch is up, everyone will see it. Including me!
Indiana Rambler
Re: Indiana Rambler
Postby JasenC » Mon Jun 06, 2022 7:04 pm
It's looking great.
For the rear are you just planning some type of roll pan like a pick up w/o a bumper?
JasenC
Images: 122
Re: Indiana Rambler
Postby tony.latham » Mon Jun 06, 2022 9:51 pm
A really really fine job. :applause:
