The details might take a lifetime as you see new things. The pans are a great idea.
WesGrimes wrote:That turned out really great. I like the trim details on the side doors.
I thought that the boat vent on the side of your trailer was the exhaust for your ac unit. What does the vent feed?
2bits wrote:Wes, you are close. The vent on the side feeds the clean air intake on the side of the AC, the exhaust is separated and will go out the bottom.
2bits
Did some more work on the galley this week. I got three coats of poly on both sides of the doors so they are done.
2bits wrote:OK I am not gonna tear this thing down before it is even finished! Apparently, one of the screw holes under the galley wall trim did not seal properly or my three coats of cpes and poly weren't good enough on the end grain, so we have delamination...
The other side of the camper is perfect. I think this is a result of that one damn time I went camping and it rained for 18 hrs straight and I got my initial delam. So I guess I will pull that trim and soak the entire area in CPES to fill the gaps, then seal the end grain with their fill-it. When I extend the trim down to the rest of the profile in the rear that should cover most of the ugliness. I hope it works.
