Today was not a successful day.
My next step in the build is to apply trim on the roof of the swoop. Because of the contours of the roof line, the trim pieces must bend, and in order to bend without snapping, the trim must be steamed. That being the case, I designed my own steamer...my ghetto steamer.
I put the wood inside this section of vent pipe, then I suspended the pipe from my patio cover. I wheeled my BBQ under the pipe so the steam from a pot of boiling water would rise directly into the pipe and soften the wood.
Three hours of steaming had almost no effect. :-( On two plan B.
Plan B was to cut a piece of trim into three pieces, then glue the three pieces together while clamped to a mold with the exact contour of the roofline (this section would have been the contour at the rear of the TD). The pieces didn't laminate nicely because I couldn't get even pressure across the entire surface.
On to plan C. Problem is, I haven't figured out plan C.
At least I was able to install the cleat that the curtains will attach to.
