Travel trailer with slide out build
Postby StandUpGuy » Mon Nov 28, 2011 4:11 pm
Very professional!! I am extremely impressed. Nice job. :applause:
I have a question. On your first trip with it, did you use the toilet? I have the same set up started and was considering changing it. I am concerned about solid matter flow into the tank on the horizontal pipe. Your horizontal is longer than mine so if yours works OK then mine should too.
StandUpGuy
Images: 52
Postby Dmanrick » Mon Nov 28, 2011 5:19 pm
Oh yeah we used the toilet and it worked great. I did leave the little water hose connection off when we were using it but there was not a problem at all. I had done this before when I put a toilet in our old pop up and never had a problem.
Just remember to cut the springy hose as short as possible so it doesn't sag. Also the 90 degree fitting was a little hard to find.
Dmanrick
Postby StandUpGuy » Mon Nov 28, 2011 10:27 pm
Dmanrick wrote:Oh yeah we used the toilet and it worked great. I did leave the little water hose connection off when we were using it but there was not a problem at all. I had done this before when I put a toilet in our old pop up and never had a problem.
I appreciate the advice and the detail. Thanks. :thumbsup:
StandUpGuy
Images: 52
Postby vwbeamer » Fri Dec 09, 2011 11:13 pm
Very nice :applause:
vwbeamer
Postby IndyTom » Sat Dec 10, 2011 12:28 am
Extremely impressive. I just finished reading the complete build thread and I am utterly blown away.
Never trust a skinny cook
IndyTom
Images: 42
Postby Woodbutcher » Sat Dec 10, 2011 9:43 am
You did a great job. It's very well thought out. I was scrolling through the pictures thinking, How big is this thing? Then I get to the full trailer shot and see it is still a compact footprint. You did a real nice job fitting so much in a small space. :applause:
Woodbutcher
Postby Dmanrick » Sat Dec 10, 2011 11:00 pm
Thanks guys. This one actually has quite a bit of room because of the slide out.
I'm already thinking about the next one..... :)
Dmanrick
Re: Travel trailer with slide out build
Postby droid_ca » Sun Oct 21, 2012 1:07 pm
What was the overall weight of this trailer??
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Dmanrick » Sun Oct 21, 2012 3:51 pm
Never got it weighed. My 4 runner pulled it ok but you definitely tell it was back there. I just took it to the lake and it has been parked there ever since.
Dmanrick
Postby droid_ca » Sun Oct 21, 2012 5:49 pm
ok how much extra weight would you say your slide out set up was??? Thanks thinking I might be able to do the same style of a crank out for my little cabin
“Fide Canem”
droid_ca
Images: 176
Postby Dmanrick » Sun Oct 21, 2012 8:07 pm
It wasn't heavy at all. The wife and I lifted it into place with no problem whatsoever.
Dmanrick
Postby droid_ca » Sun Oct 21, 2012 8:21 pm
Dmanrick wrote:It wasn't heavy at all. The wife and I lifted it into place with no problem whatsoever.
That is what I wanted to hear I might of worked out a deal to get a frame welded up and need a good way to do a slide out I like how yours is setup thank you for the detailed pictures hope fully my friend can make sense of it all and I can do something simular (he was a millwright) Thanks again
“Fide Canem”
droid_ca
Images: 176
Postby Dmanrick » Sun Oct 21, 2012 9:10 pm
No problem. It really works well and makes all the difference in the world as far as room in that thing.
Dmanrick
Users browsing this forum: Bing [Bot] and 17 guests
