Good progress this weekend, but always slower than I'd hoped. Lots of Hurry up and wait with these things...
Torque Washers
![Image](http://www.m2-photo.com/photos/i-FdHVVvt/0/M/i-FdHVVvt-M.jpg)
Primed Torque Washers. Probably an unnecessary step, but my teardrop OCD kicked in and painted them anyway. I'm using stainless carriage bolts, washers, and nuts. I have looked for stainless torque washers without success. Since these are not going to be exposed to weather and sealed in the raised deck, I'm sure that they will be fine.
![Image](http://www.m2-photo.com/photos/i-NkP58kc/0/M/i-NkP58kc-M.jpg)
I used a flush trim bit to ensure that my primary deck was trimmed to the same size as the trailer. Nifty little router bit.
![Image](http://www.m2-photo.com/photos/i-tcCdFvf/0/M/i-tcCdFvf-M.jpg)
I will be creating a raised deck to hide the electrical wiring and A/C return. Here are a few of the side pieces cut and temporarily clamped for fitting.
![Image](http://www.m2-photo.com/photos/i-d7fSFxR/0/M/i-d7fSFxR-M.jpg)
Since my teardrop is wider and longer than a standard sheet of plywood, I used a biscuit jointer to attach all 3 pieces together. I've sanded down the top of the plywood and will be using fiberglass to seal and strengthen the joint.
![Image](http://www.m2-photo.com/photos/i-LkJWGvN/0/M/i-LkJWGvN-M.jpg)
Here is the fiberglass cloth before resin. Once the top of this is complete and dry, I'll flip the entire thing over and repeat on the other side.
![Image](http://www.m2-photo.com/photos/i-484rpBK/0/M/i-484rpBK-M.jpg)
Once the epoxy resin is applied, you can see through the cloth.
![Image](http://www.m2-photo.com/photos/i-tZFN2HB/0/M/i-tZFN2HB-M.jpg)
Not sure I've seen this approach, but I'm running the return air duct in the raised floor. I'm using a standard aluminum downspout as the conduit, and needed to use a Dado bit to remove some of the plywood so that it would fit.
![Image](http://www.m2-photo.com/photos/i-VjX4BjL/0/M/i-VjX4BjL-M.jpg)
I fiberglassed the exposed/recessed part of the deck. Since I removed almost 1/2" of material, this should ensure that it stays strong when I need to flip it over.
![Image](http://www.m2-photo.com/photos/i-dXgspLZ/0/M/i-dXgspLZ-M.jpg)
Next steps are to flip over and fiberglass the joint on the deck. Sand the entire thing and apply Truck bed liner. Then I can permanently attach the deck to trailer frame. I won't be able to work on this for a few weekends, but I did make some progress.
