My build of Benroy Style Trailer
Re: My build of Benroy Style Trailer
Postby AlgoDan » Sun Mar 24, 2013 11:35 am
Thanks KC, Trying to get it done. I plan on camping in 4wks. time....
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby KCStudly » Sun Mar 24, 2013 11:54 am
Looks doable. Stay on it.
Postby AlgoDan » Sun Mar 24, 2013 2:10 pm
Also finished up CPES application before sealing Aluminum to the roof...
103570
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Sun Mar 24, 2013 3:35 pm
I had to fit the aluminum on the hatch, then need to cut out latch holes. Then make some trim pieces for the edging.If all goes well should have it done by next weekend
103593
103591
103590
Build Journal
AlgoDan
Images: 238
Postby S. Heisley » Sun Mar 24, 2013 7:55 pm
It looks like you're doing a good job, Dan, and getting close to done!
Here's to camping this summer! :thumbsup: :applause:
Postby AlgoDan » Sun Mar 24, 2013 8:37 pm
Thanks, I cant wait to finish its been a long winter.....Here's to Camping :beer:
S. Heisley wrote:It looks like you're doing a good job, Dan, and getting close to done!
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Mon Mar 25, 2013 4:49 am
So as I build, I will incorporate roof racks for my kayaks. I have made up mounts for it but still need to form the cross bar. The cross bar will be
3.5 x 2.6 x .090 Alum. channel. In the design there will be awning tubes built into the channel that slide out 6ft.The awning is not large, but enough to keep the area dry when need be. Also when we camp I throw up either my 20 x 30 or 16 x 20 tarp up for full protection...
103572
Build Journal
AlgoDan
Images: 238
Postby davidniebeling » Mon Mar 25, 2013 9:12 am
Lookin' sweet. I like your design for a roof rack.
davidniebeling
Images: 50
Postby AlgoDan » Mon Mar 25, 2013 9:30 am
Thanks David, I thought I would do something multi-functional while I was at it....
davidniebeling wrote:Lookin' sweet. I like your design for a roof rack.
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Mon Mar 25, 2013 1:49 pm
Ok now that the skin has been fitted to hatch, I did the latch cut outs to make sure all functions work and for clearance. I could not believe that when closed they actually drew the door in snug. So adjustment will be made once the weather stripping is in place. Tomorrow I will make up trim caps for the edging also.
103631
103632
Build Journal
AlgoDan
Images: 238
Postby KCStudly » Mon Mar 25, 2013 4:45 pm
AlgoDan wrote:I could not believe that when closed they actually drew the door in snug.
Of course they did. Your work is impeccable and you obviously used the 6 P's...
Prior Planning Prevents P*ss Poor Perfomance.
I am jealous over how quickly this is coming together for you. :applause:
It is looking good. :thumbsup:
Postby AlgoDan » Mon Mar 25, 2013 5:14 pm
Thanks KC you crack me up, thats funny the 6 P's but its true...Planning is key.. Cheers :beer:
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Tue Mar 26, 2013 10:11 am
As with my aluminum frame trailer, I fabricated spring mounts out of 3/16 steel. They will get powder coating prior to install, all I need to do is size up my shackle length and get that part of the build out of the way. Oh ya if you look closely I missed end holes in my mount. In Autocad drawing/dxf if you miss anything then it wont be there when you lazer cut it...dumb dee dumb dumb...
103646
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Tue Mar 26, 2013 2:10 pm
Oh another photo I haven't shown was the latch backing plate mounted. I screwed 1inch.S.S screws and construction adhesive to fasten. Reason was for a secure locking point, and a tight seal. Just adding a little beef lol....
103658
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Tue Mar 26, 2013 3:25 pm
Do you mean the edge moulding for the roof /wall?
biziedizie wrote:Hey I was wondering if yo had a skew # for the window trim, I can't find it at HD.
Build Journal
AlgoDan
Images: 238
