From The ashes
Re: From The ashes
Postby noseoil » Sun May 22, 2016 8:42 am
Aluminum ages naturally by forming a layer of "rust" or aluminum oxide on the surface. It's sort of dull looking on the surface when this happens.
The advantage aluminum has over steel is that the surface "rust" acts as a barrier layer to prevent any further oxidation from happening beneath it. Unless it's in a really harsh environment, it stops & reaches a stabilization of this oxide formation, which protects the metal under it from further damage. Great stuff!
137905
noseoil
Images: 670
Re: From The ashes
Postby KCStudly » Sun May 22, 2016 10:03 am
We're watching. You're doing great. Keep posting. :thumbsup:
Re: From The ashes
Postby ELM » Sun May 22, 2016 10:52 am
Yes you are being watched and your doing great work so keep the pictures coming. What are you using for trim on the edge where your walls and roof meet.
My Build journal. viewtopic.php?f=50&t=65395
ELM
Images: 176
Re: From The ashes
Postby flyguide » Sun May 22, 2016 3:11 pm
After some advice from Noseoil ( this name brings on many thoughts) :thinking:
I was able to cut out the hatch, lights and vent hole. I didn't realize that the MaxxairII had to be completely disassembled to install it. Through off my schedule for the day.
As you can see got a great pic of my finger with camera phone. First pic is a video.
flyguide
Re: From The ashes
Postby flyguide » Sun May 22, 2016 3:21 pm
Thank you all for the encouragement.
ELM wrote:Yes you are being watched and you doing great work so keep the pictures coming. What are you using for trim on the edge where your walls and roof meet.
I have the original trim from the old trailer, it has to be scraped down and cleaned but it is all pre-bent in the shape I need. I will have to find a supplier of more trim, since I redesigned out the faults I found slightly changed the shape of the original trailer, I'll need a 3 Ft section to complete the job.
flyguide
Re: From The ashes
Postby SeaFlea » Sun May 22, 2016 4:57 pm
Nice work Frank!! That l'il trailer is lookin' sweet!!!
:beer:
SeaFlea
Images: 10
Re: From The ashes
Postby flyguide » Sun May 22, 2016 6:26 pm
noseoil wrote:Aluminum ages naturally by forming a layer of "rust" or aluminum oxide on the surface. It's sort of dull looking on the surface when this happens.
Thank you for another lesson. :beer:
flyguide
Re: From The ashes
Postby flyguide » Mon May 23, 2016 8:57 pm
The green drakes and march browns are calling me to go fishing for the next week. See you all next week. :D
flyguide
Re: From The ashes
Postby ELM » Mon May 23, 2016 10:56 pm
Have fun and good luck. :beer:
ELM
Images: 176
Re: From The ashes
Postby flyguide » Tue May 31, 2016 5:07 pm
Got on it bright and early today. I measured up the cabinet doors, now I just have to make them. Battery was dead so I looked back at wiring. Realized that I wired battery circuit to circuit with no fuse. That didn't work well. Got the fuse box wired up and finished DC wires. AC needs one receptacle inside and thats done. I'll secure the rest of the wires in the morning.
I'm starting to get into the little $#!+ now, where its a lot of work and no big show.
flyguide
Re: From The ashes
Postby ELM » Tue May 31, 2016 8:10 pm
Your making progress and it looks good. :applause: Keep plugging along and you will get there.
ELM
Images: 176
Re: From The ashes
Postby flyguide » Wed Jun 01, 2016 10:08 pm
Striped the marker lights off the fenders and sanded, primed and put one coat of paint on them. The battery issue is resolved. I have been researching radio antennas.
Does any one have a suggesting for an antenna, that wont put a hole in the beautiful alum skin I just put on?
flyguide
Re: From The ashes
Postby ELM » Wed Jun 01, 2016 10:21 pm
ELM
Images: 176
Re: From The ashes
Postby flyguide » Thu Jun 02, 2016 8:50 am
ELM wrote:Check out these. http://www.ebay.com/sch/Radio-Antennas- ... 520Antenna
Thanks ELM these are some of the antennas I've been looking at. I was wondering if any body has tried these?
Second coat of paint on fenders. They'll be ready to hang when I get back.
Also whats is the best way to apply the trim with butyl tape? Do I cover the sides and roof? Do I fill the small seam that was created by routing with chalk first? Someone?
Going back up to camp for another round of fishing. If I keep going fishing I'll never get this done. LOL
If I knew retirement was this much fun,
I would have done it at 21.
flyguide
Re: From The ashes
Postby aggie79 » Thu Jun 02, 2016 11:50 am
flyguide wrote:I have been researching radio antennas. Does any one have a suggesting for an antenna, that wont put a hole in the beautiful alum skin I just put on?
I know you said you didn't want to put any holes in the aluminum, but I used this outside-mounted antenna:
The design fits the retro nature of the teardrop. The antenna seals really well to the side - no leaks - and has great reception.
