I can’t wait to get out camping next!
featherliteCT1 wrote:I continue to learn from your solar setup postings.
If you connect the two portable panels and the one roof mounted panel to your MPPT controller at the same time, in full sun, do you need to worry about exceeding the MPPT controller's 15 amp output rating?
...would likely not get the solar input 5 volts above battery voltage, which is the minimum for the Victron 75/15 to start charging.
tony.latham wrote:...would likely not get the solar input 5 volts above battery voltage, which is the minimum for the Victron 75/15 to start charging.
Is this just a Victron controller issue? Or perhaps an MPPT? I'm using a Renogy PWM...
but that is just a guess.
Users browsing this forum: ricky herbold, tony.latham and 12 guests
