Morning,
Here are the photos from the lamination work I have done. I'm pretty excited that the right side piece, once completely dried, had no spring back (shown below). The other two photos below, show the process I used to laminate the 'bows'. I didn't get photos of each step because I wasn't sure if it would work.
One photo I didn't take was a shot of all the 'strips' laid out on the ground. I start by laying the strips out on the ground/table so I can apply glue to one side of each strip. I did not apply glue to the last strip, as it is the 'top' or 'outside edge strip', so it doesn't need glue. I then took the strips and stacked them one on top of each other. I picked up the stack of oozy glued up strips and then started to clamp them to the blocks you see nailed/screwed to the side of the trailer. Start at the bottom and make sure all the ends are nice and even. Work your way up the stack towards the other end. Clamping the stack to the side of the trailer and the little former blocks as you go up. Make sure there are no gaps between the strips. Make sure the ends stay lined up nice and even. Also make sure you maintain that consistent curve with the edge of your former. In this case, that'd be the side of the trailer.
Hopefully these photos help illustrate my madness. One set will end up glued to the sides of the trailer. However, I plan to make 2 more of each side (to form the hatch), I don't want these to stick to the trailer just yet. The blue tape is there to keep the laminated ribs from sticking to the side of the trailer.
Steve - Thanks for the shot of the door. That piece makes sense. It's the hatch that confuses me. My hatch was basically completely disassembled. Where does the weather strip go on the hatch? Regarding the seal, I've seen P shaped seals for sale. Let me know if you can't find where to get it, and I can send you a link.
Mike - Please send shots of your hatch and how you plan to seal it up.
Thanks gang,
Ted
