S. Heisley wrote:It's looking great. Keep up the good work!
Thank you. It's getting there. Once piece of wood at the time.
Looks like we *should* have the walls up and permanently attached in the next couple of days. Since the last photos, I have cut the bulkhead wall to fit. That was a little uneasy, but not too difficult. Just had to take me time and the the angle at the top where it meets the roof right. I almost cut it too short as I was trying to decide if it went to the top of the ceiling or the top of the roof. I decided on the roof... and glad I did.
Also, I got some of the back roll pan built. Still need to skin it, but at least the top is in place and we can work off of that for the hatch bottom. Will do more on that once things are closer to aluminum.
We have decided to go camp-inn style on the AC. For those not familiar, Up top, in the middle, vent out the back just forward of the hatch. We have done quite a bit of measuring on this and *think* we have it right.
Basically it is just going to be a box for the AC to sit in right in the middle of the back of the cabin. It will be glued, screwed, sealed, and CPESed, then painted on the inside. There will be a drain in the corner that goes straight down, through the back cabinets to the ground. Basically the entire box will act like a drain pan for the AC and the little bit of rain water that will get it. The top of the entire thing will be sealed with a baffled vent (think reverse hood scoop). Cabinets will be just basic cutouts with push latches. 2 at the top, 2 larger at the bottom. 1 open space in the middle under the AC for drinks, keys etc.. or if we decide to put a TV in at any point.
Anyways, all that to say this. Getting the pieces of that worked out is the next step, then to take it all apart and get ready to glue it up permanently. But first...
Still need to:
* cut out the side wall pieces for the hatch. I have been dreading this since, well, probably since day 1. BUT Now is the time!!
* There is only 1/8 presently hanging over the edge of the frame at a depth of 4" SO.. I have decided to add a little bit of backing to that, just glue it in place and clamp it. I figure this, along with the AL will give it less chance of getting it by road debris and getting damaged.
* Then seal this overhang piece along the bottom. There is a very tight gap between this and the frame, so I have to do this before the walls are permanently attached to the floor.
* And oh yeah, we need to notch out the overhang as well where the torsion arm makes contact. I have noticed that it is just now touching the overhang (as expected). So, I will take off one wheel and do this and then copy to the other side. While I have the wheels off I think I will take the new chrome wheels up and get the tires switched to them. Time for a little BLING BLING
