Ok here we go...PMF!
Re: Ok here we go...PMF!
Postby OP827 » Sat Dec 03, 2016 8:22 pm
That is a nice sound system you got there! :thumbsup:
OP827
Images: 414
Postby dales133 » Sat Dec 03, 2016 11:51 pm
Cheers guys
Well its official...im ready to put the cabin on.
Rod tubes in and front power wired in.
Just need to get some bodies organised to get it on the trailer , hopefuly one night this week.
dales133
Postby OP827 » Sun Dec 04, 2016 1:20 pm
You've done it! Congrats! Are you going to permanently fix it or it can be removed for maintenance or repair? :thumbsup: :thumbsup:
OP827
Images: 414
Postby dales133 » Sun Dec 04, 2016 1:26 pm
Still debating that.
In theory it could be disasembled but it will be a huge job once all the side cladding ect is on.
Im also considering glueing and sealing the floor to the trailer for strength and protection.
Ive overbuilt the draw runners and thats about the only thing that could fail.
But still causes me some dread
dales133
Postby OP827 » Sun Dec 04, 2016 7:20 pm
I am just thinking out loud here. How about using butyl caulking OR rubber-like polyurethane caulking(like I did on my build floor). You can then theoreticaly cut it loose in a very unlikely event of required repair. I like how my polyurethane caulking is cured, it is like a nice medium density rubber. I think it will be easir to separate if needed, butyl is very sticky and will stick to any blade if a separating cut is attempted.
OP827
Images: 414
Postby dales133 » Sun Dec 04, 2016 7:34 pm
Yea thats what i was going to use
dales133
Postby Captain Monkeyshines » Mon Dec 05, 2016 9:13 pm
We used butyl tape between the floor and the trailer. It's mostly permanently attached to the frame. We can still remove it if we have to, but it world have to be serious damage for us to want/need to. It is a very stable and sealed attachment. I say security,stability, waterproof takes precedent over ease of removal.
Nice looking set up!
Sent from my SM-G900V using Tapatalk
“When You're Alone”
When you're in the kitchen, you've got to behave
You don't put metal in the microwave
The knobs on the stove are “hands off” no doubt
And when you make toast, don't use a knife to fish it out!
When you're alone, when you're alone
You got to stay safe when you're home all alone.
When you're alone, when you're home all alone
You got to make sure not to die, or choke or burn the house down.
Postby noseoil » Tue Dec 06, 2016 8:21 am
Dale, looking good! I chose to use the foam sealing (sill plate) material we used at work. It's just a soft foam (no adhesive) about 4" wide which is used for wood framing construction in the housing industry here. Normal use is to go between the bottom plate of the wall & the concrete slab, to keep moisture out of the wall from wicking.
It will seal well, compress to almost nothing & was very "cheap" since the rolls are long & I only needed a few feet for my build. I used 9 bolts to hold the camper on my frame. No problems since doing it this way. I didn't glue the camper to the frame since gravity & fasteners seem to work well enough here in Arizona most of the time. Not sure on your side of the world, might need some glue since everything there is upside down.....
137905
noseoil
Images: 670
Postby KCStudly » Tue Dec 06, 2016 9:54 am
noseoil wrote:... on your side of the world, might need some glue since everything there is upside down.....
:rofl:
Postby dales133 » Tue Dec 06, 2016 11:45 am
Thats funny right there!
I know the stuff we use it here to vut ours mostly has adhesive backing one side.
The aluminium on the subfloor is goinv to come up around an inch past where the cabin floor meets the top of the trailer so i want to try to keep water from getting in there.
Last night a mate and i got the fence post rollers under the camper and moved it back so i could spray the underside with body deadner in preperation fot fitting it this weekend so i guess ill have to make a decision by then
dales133
Postby dales133 » Sat Dec 10, 2016 12:48 am
Ill just leave these here...[SMILING FACE WITH SMILING EYES]
dales133
Postby KCStudly » Sat Dec 10, 2016 10:43 pm
Awesome! That is a huge milestone to be proud of. :thumbsup:
Postby dales133 » Sat Dec 10, 2016 10:46 pm
Thanks mate.
Just took it for a spin, it tows beautifully.
As i know everyone expected shes on the heavy side.
I just put it over the weight bridbge.
Ill calculate it and post it.
What do you recon she weighs?
dales133
Postby dales133 » Sat Dec 10, 2016 11:01 pm
Actualy realy close to what i was hoping for.
740kg
dales133
Postby KCStudly » Sat Dec 10, 2016 11:02 pm
Eh, 1350 lbs (612 kilos) at a guess.
