I bought it off a mate who had started building a trailer inside it... and gave up after realising they don't build themselves and you have to put some time in to achieve the end result.
First job is going to be to take the part build apart and see what is useable.
Good points so far:chassis is solid, It tows fine, It's dry, has lots of useable trim, and a good door, a near new fiamma sky light/ roof vent, and some useable timber and ply included.
Not so good points: Chassis isn't galvanised, Its got a 1/2 built teardrop inside that is poorly constructed, and is going to need to be taken apart before we can start a fresh. Not a lot of stuff to sell on as it's been mostly stripped.
So here we are, the Donor
Spec is going to be 8ft long, about 5ft wide, lightweight, possibly like the Coppertop.
Basic for me. Probably 2 side doors, rear hatch, and maybe a pass through from the cabin.
Heres a few of the inside as it stands
I've thought about doing a Jim Dandy, the one with the hatch at the front, but still undecided as I like the modernistic shape
