I have been a bad forum member....Sorry!
Postby ubear7 » Mon Jul 25, 2011 10:58 am
"Scraps" is finally started. After being a member and reading since Feb 2010, I finally started to make some saw dust. The bad part is I have not posted anything yet. So this is my official apology and build journal. I actually started about 16 weeks ago. I only work on it on Saturdays and skipped a couple at that. So far I have 14 saturdays and Memorial Monday. :)
I will post the pics as soon as I get them resized and uploaded.
PROMISE!
:lol:
1998 Dodge Ram 3500 4x4, 2006 Dutchmen Denali 33rlbs
ubear7
Images: 5
Re: I have been a bad forum member....Sorry!
Postby Steve_Cox » Mon Jul 25, 2011 2:11 pm
ubear7 wrote:"Scraps" is finally started. After being a member and reading since Feb 2010, I finally started to make some saw dust. The bad part is I have not posted anything yet. So this is my official apology and build journal. I actually started about 16 weeks ago. I only work on it on Saturdays and skipped a couple at that. So far I have 14 saturdays and Memorial Monday. :)
PROMISE!
:lol:
There is nothing worse that sneaky builders... :lol:
:pictures:
Steve_Cox
Images: 196
Postby mikeschn » Mon Jul 25, 2011 4:17 pm
You can redeem yourself by posting pictures! ;)
build
Postby 3822sean » Mon Jul 25, 2011 7:39 pm
dont mean to Image but you could post some pics :thumbsup:
3822sean
Images: 37
Postby ubear7 » Mon Jul 25, 2011 8:45 pm
Built the trailer on 5/30/10 then it sat and turned from red to pink. (glad it did it before the build) I would hate to have an pink and aluminum teardrop.
:lol:
I officially started my build on 3/19/11 by painting the trailer black.
The saw dust finally started flying on 4/8/11.
on this day I also drew the profile
4/15/11 cut out the sides, port holes, and mocked up the walls
4/22/11 insulated walls and installed boards on inner walls
4/30/11 trimmed inner wall to outside wall, cut out door, out up walls and installed spars
5/7/11 framed the partition, mocked up the A/C and cut out vent for A/C
5/21/11 installed inner stained skin, insulated around the A/C, and wired for 120v ac and 12v dc.
5/28/11 installed floorboards, cut out inside shelf, some galley work
5/30/11 framed hatch
6/10/11 installed interior lights, finished wiring converter
6/18/11 insulated roof, installed outer and hatch skin
Vacation Break
7/16/11 fit and cut aluminum skin
7/23/11 installed butyl tape along the roof edge, permanently installed the aluminum skin and trim, clearance lights, porch lights, power cable hatch and tongue jack.
Well there you have it, you are all caught up.
:applause:
Sorry once again for the Looooooong post.
ubear7
Images: 5
Postby LDK » Mon Jul 25, 2011 8:59 pm
I bet your flasher is worn out on your camera. :lol:
I guess now you're officially redeemed. :lol:
Did you float your aluminum skin or did you glue it on?
Looks great!!!
LDK
Postby 3822sean » Mon Jul 25, 2011 9:15 pm
looks great thats a lot of pics Image
that will make everybody happy
3822sean
Images: 37
Postby LDK » Mon Jul 25, 2011 9:17 pm
I think I counted 65 pics so far. Probably broke the record!!! :thumbsup:
LDK
Postby JohnnyH » Mon Jul 25, 2011 10:19 pm
:thumbsup: Looks great so far.
I like the woodwork on the inside,
is that flooring?
JohnnyH
Images: 6
Postby ubear7 » Mon Jul 25, 2011 10:49 pm
I really didn't plan on putting them all up at once. I started to a couple of times but got bogged down when having to convert them and upload them....
Yes that is flooring. I had thought of this and then saw it in a thread and it convinced me to do it. My wife and I are both happy with the way it looks.
ubear7
Images: 5
Postby ubear7 » Tue Jul 26, 2011 12:32 pm
I left about 1/4" overhang on each side of the hatch. I plan on using the insert trim on the outside and a flat "scrap" piece of the aluminum on the inside part of the 1/8" luan ply. The 1/8" luan was slightly damaged at a bottom and top corner. I wanted to strengthen this up a bit. Could I just use resin and brush it on both side of the luan? Or should I use some glass mat also. I have never done fiberglass but seem pretty simple especially since it doesn't have to look nice cause it will be covered. Or do you guys have a better idea?
ubear7
Images: 5
Postby CAJUN LADY » Tue Jul 26, 2011 12:51 pm
Great job you are doing! Thanks for sharing your pictures. :thumbsup:
Becca
~Cajun Lady~
CAJUN LADY
Images: 74
Postby campmaster-k » Tue Jul 26, 2011 1:13 pm
I like the round window.
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby ubear7 » Wed Jul 27, 2011 8:41 am
Thanks to everyone for the kind words . I saw the round port hole windows on at least two others in the Hall of fame pics and we loved the way they looked, so I incorporated them into the build. Also not mentioned with the pics is I tested the A/C. It went from 94 to 68 deg and humidity went from 67 to 46 in a little over 1/2 hour. This was with plastic bag taped over the door and window opening. The vents in the floor worked well in that the unit did not freeze and took the humidity out of the air. I am still going install a diverter to send the hot air straight back and away from the intake cooler air. :thumbsup:
ubear7
Images: 5
Postby Deryk the Pirate » Thu Jul 28, 2011 11:11 pm
Great Job! Like the ac unit!
Deryk the Pirate
Images: 158
