Yes that means I have #2 and #3 already on the drawing board haha!
I realized that I have a new AC unit, and 5 sheets of 4x8 black aluminum leftover from the LT build, that's $700 right there. I need to do a budget and quick build but still cool looking. So using what I have learned that I do not need from my last build... my plan is to also use the dimensions of the material I have available to me. It will be a 4x8 design which will greatly simplify the build. To further save money and time, I plan on using the little square harbor freight trailer, and instead of moving the axle back, I will extend the front of the frame. It will have 4x8 plywood walls from the box store, stained on the inside and the black aluminum on the top and sides of the exterior. A 1/8" ply headliner will sit on top of the spars which will be exposed to the interior and the aluminum exterior will sit right on top of that. No insulation and no 110 or 12v power beyond a well placed power strip. I found with the LT that was all I ever needed, that will save loads right there. Another time saver is there will be only one door, no galley or hatch, and have just one shelf inside. The door will be square to ease construction. I'll use Grant's T molding, black crank out window, door latches, and a harsh environment plastic hinge. The AC window unit will sit sideways on the inside shelf on two drawer-slides, and there will be a latching cover on the side of the teardrop so the AC unit can slide in and out as needed, no special ducting needed. All this combined should make for a quick and easy but still very good quality and cool looking build. I'll need to do SOMETHING about those wheels though but for now I'll probably just paint them gloss black since everything else will be black.
I was toying with the idea if building it like a cargo trailer using metal framing because it reduces the rot opportunity, and reduces build time, but I struggled with the door and AC unit areas. I ended up where I was welding a whole frame together. Plus attaching the roof and what kind of spars was leaving me scratching my head so I fell back on the old faithful plywood. Remember the mantra: Seal the grain... Seal the grain... Seal the grain...
The shape will be somewhat of a KIT style with the axle way at the back
The interior is going to be very similar to the Dragon Wagon stylistically with no galley, one shelf, and exposed stained spars:
