Already, building a teardrop is more like a journey than it is a project. Last night, after I finished my profile, I had second thoughts. I started looking at other profiles and started thinking something was wrong. I was wondering if I had made all the right decisions. What was I going to regret? Then it clicked, the problem was not the profile...
So, this morning when I looked again at my profile, it just fit. No more looking back, I am cutting wood.
I like clean lines, clean cuts, sharp tools and things that fit. Having said that, using a jigsaw really was not the best choice. Right now I am questioning why I even own a jigsaw as I really do despise them. For all of my efforts with a jigsaw this was my reward.
- Cut made with jigsaw.
- 2012-07-25 11.24.30-small.jpg (65.98 KiB) Viewed 3515 times
I tried to smooth things out using rasps, block sanders and electric sanders. It became clear that I was on the wrong path. So, at the risk of sounding compulsive, I found a little more elaborate solution for my profile template.
I cut a 3/16" x 3/4" strip of oak that was about 12' long. I glued it edgewise on the template, leaving a little of the edge of the masonite hanging out. I then used a formica bit in my router to do a quick flush cut.
- Setup for router cut.
- 2012-07-25 17.33.11-small.jpg (77.38 KiB) Viewed 3515 times
And here is what the edge looks like now.
- Finished edge cut with router and formica bit.
- 2012-07-25 18.12.15-small.jpg (88.73 KiB) Viewed 3515 times
I did not let the glue dry completely so when I was finished, I pulled the oak strip off leaving only the masonite for my final template.
This, I can live with.
