I haven't decided on how I want to skin it yet though. Here are my options.
Option 1. Skinning it with aluminum coil stock attached right to the frame with no sheeting under it, then having the inside sprayed with insulation foam. I like this idea the most because it is the lightest weight and the spray foam would act at a glue to keep everything together and add a backing behind the aluminum siding. Although I haven't heard back from the local insulation company to find out how much it would cost.
Option 2. Skinning it with aluminum coil stock attached to the frame with sheeting under it only on the front. Then insulating it with sheets of Styrofoam and suing great stuff to glue the foam to the studs and skin. That won't be quite as strong as using the spray foam but should still add a lot of strength to the frame to keep it from racking. I think this will be much cheaper than using spray foam.
Option 3. Skinning the sides and roof with painted hardboard, and skinning the curves at the front and rear of the roof with painted canvas. I think this could look really cool with an aquamarine and cream paint job. And if the canvas curves were painted cream they would act as sky lights. The problem I come up with this method is it is heavy and I don't know how well the hardboard would hold up.
Option 4. Cover the whole camper in canvas with nothing under it. This would also allow me to do the aquamarine/cream paint job and would have a very unique look to it with its ribs showing through the canvas but I can't figure out how expensive it will be because I don't know how many gallons of paint it will take.
If anyone can suggest any other cheap and light coverings I would like suggestions.
My goal is to keep it as light weight as possible for several reasons. The camper I have now weighs around #1800 loaded, and I tow it about 500 miles a week and it is just too heavy to tow that much for my car. I am also building it so the camper shell can be removed from the trailer so I can use the trailer on its own and use the camper shell as an ice shack in the winter so I want to keep it light enough to load and unload by myself.
