My teardrop is almost done, but some of you wanted pictures from my build.
So, here we go.
This was my starting point, the frame donor. An old caravan from 1976. In Norway it's not allowed to make your own frame
Frame shortened and new attachment points for cabin welded in place.
Sub frame taking shape. 30mm x 70mm.
Battery compartment in aft section.
Floor was made of waterproof plywood, same type they use on trailers. The forward compartment are for camping furniture.
Frame returned from sand blasting and sink coating.
Attachment of sub frame and floor.
Walls made, my cabin is 3 meter.
Test fit of door and window.
Reinforcement on the edges and for door and window glued.
Markings for the "stiffeners", roof attachment.
Flooring, with forward compartment hatch installed.
Upper part of wall.
Wall + skirt. Makes it look low.
