Whetzeldorf no. 4
Whetzeldorf no. 4
Postby prohandyman » Mon Dec 24, 2012 8:19 am
100176
I guess I never started a journal on this build so I better get caught up. This one will be similar to no.3 with a few dimensions tweaked and some minor changes. Since each donor pop up is different I use what they supply as much as possible. Here is the frame after shortening, adding the drop floor framing, moving the axle, and as you can see it had front stabilizers, which were in the way of the step on the curb side, so I removed them. Do not believe there is much need for them.
And here the floor has been installed along With the wheel wells. They require some modification but not much.
100234
The cabinets changed slightly, as the donor had plastic "totes" as drawers behind a common door. I used the same paneling as the walls for door panels. You can see the power converter on the far left, new mini fridge it the center, and the drawers right of it. The drawers hang on aluminum angle as slide brackets. I added a wood brace on the back of each drawer, as they tended to tip as you pulled them out ( I guess Starcraft didn't care if you dumped the contents as you pulled the drawer out).
The opening on the right serves 2 purposes...an area to stow the new, 2 burner propane stove during travel, as it is removed and slid onto a bracket on the outside of the camper for use when parked. And connected to the gas line via a quick connect and hose that stows thru the wall.
And has a DVD player mounted for the flat panel tv, which will attach to the mount seen above the counter. Shoes can be stored next to the stove.
3 outlets for appliances are added around the counter, all connected to a GFI circuit from the converter, supplied by the pop up. The donor also supplied a sink, which I have omitted in the past, but installed here, and have yet to decide if I will install the pressure hose connection on the side. I may just wait until I
have a buyer and then decide on water needs. I have the faucet and connections on the shelf.
The mattress is a 5" foam from a surplus supplier, covered from the factory.
Windows are 15x24" sliders, surplus, as is the door. It is a factory Atwood product, complete with screen door and dead bolt. I dis-assemble it and cut it and the screen door down to the height I need. Externally accessible storage under the bed, as well as an hinged access panel under the bed inside.
Not shown yet is the cubby storage area I added above the windows on the sides.
100740100739100738
Dan
prohandyman
Images: 785
Re: Whetzeldorf no. 4
Postby prohandyman » Mon Dec 24, 2012 8:22 am
Here's is the mattress in no.3, same as this one.
98957
And this is what the door will look like...98955
The walls are 3/4" , 13 ply birch, slotted, splined, and have the 1/8" pre-finished wall board laminated vertically for added strength, and to get the 62x 99" size needed.
Dan
prohandyman
Images: 785
Postby sid » Mon Dec 24, 2012 9:40 am
:thumbsup: Lookin good Dan... That's a nice size camper.
Look forward to seeing you at the Hoosier Spring Gathering
Mark and Pat
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
Postby prohandyman » Sun Jan 06, 2013 7:09 pm
Cabinets and countertops done, flat panel tv mounted, ready for door and windows.
101090
Dan
prohandyman
Images: 785
Postby prohandyman » Mon Jan 07, 2013 10:16 am
Gettin skinned alive!
101117
Dan
prohandyman
Images: 785
Postby prohandyman » Fri Jan 11, 2013 4:17 pm
Except for curtains camper is finished and ready for a buyer.
101229101228101227101226
Dan
prohandyman
Images: 785
Postby prohandyman » Sat Jan 12, 2013 9:47 pm
Went for a spin with the ole truck today.
101242
Dan
prohandyman
Images: 785
