1946 Kit rebuild
1946 Kit rebuild
Postby prohandyman » Fri Feb 01, 2013 2:42 pm
Well taking a break from the Whetzeldorfs and finally getting Kit under way. Wasn't much left of it...frame was trash, repl. axle, sides were salvageable, but decided to just, replace. The PO had tore all the aluminum and wood down and was using it to stack wood on, but kept all the parts off to the side. Some wood good, as is the windows, ice box, door hardware, etc. Here is the plan...new wood where needed, going to stick with the one door as we're all 46's, re-work the ice box, sand and shellac the wood, paint over the now painted aluminum...maybe to match my '48 Chevy truck, have a stove and bottle from a '47, so I may do the galley in all aluminum like the Sportsmasters, re-install the water tank, re-wire and install the original lights, hitch was bent so welded on a newer model Fulton hitch, have a pair of 35 Ford wire wheels at the powder coaters, thinking white wall tires, have the original flat fenders found on some 46's, but may order a pair of the newer style fiberglass fenders as found on the later ones. So a hodge podge of parts. ID tag has 12-23 of 1946 so it must have been the last one off the line before Christmas101810101811
Dan
prohandyman
Images: 785
Re: 1946 Kit rebuild
Postby prohandyman » Fri Feb 01, 2013 2:46 pm
Here is the center mount light that was on it. I re-wired it for an 1157 bulb, but may add some other taillights as well. Wire wheels before taking to powder coaters.
9954599544
Dan
prohandyman
Images: 785
Postby Junkboy999 » Fri Feb 01, 2013 9:12 pm
Hey just I just saw this on CL Is this a kit? I’m going off of the A-frame up bend and the shape.
I know you like them and spending money
:lol: Hahahahah
http://omaha.craigslist.org/rvs/3572177160.html
Junkboy999
Images: 52
Postby doug hodder » Sun Feb 03, 2013 7:32 pm
Dan...you can also get the older style glass fenders with the outer flange on them as well. I'm sure you'll turn out a great little trailer....Doug
Postby CliffinGA » Sun Feb 03, 2013 8:56 pm
Dan are you going to have it finished by CRA?
Cliff :thumbsup:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby prohandyman » Sun Feb 03, 2013 9:11 pm
Yes it does appear so . Don't know quite what to make of the axle changes though.
Doug...yes I bought a pair of those fenders a year or two ago.
Cliff...yes it will be done in a few weeks. Have every thing but fenders and tires.
Dan
prohandyman
Images: 785
Postby prohandyman » Wed Feb 06, 2013 3:19 am
Of course hatch framing was rotten so all new wood cut , glued and nailed up.
101963
Got the wheels back from powder coaters...purdy!
101962
Dan
prohandyman
Images: 785
Postby prohandyman » Wed Feb 06, 2013 3:24 am
Also got the interior sanded and shellacked
101961
Dan
prohandyman
Images: 785
Postby prohandyman » Fri Feb 08, 2013 1:04 pm
Got the body set down on the frame, the ceiling on, mattress and interior lights in, the counter top on, and started gluing the aluminum back in the galley.
101995101994101993
Dan
prohandyman
Images: 785
Postby prohandyman » Tue Feb 12, 2013 3:39 pm
Just about have the galley finished
102124
Dan
prohandyman
Images: 785
Postby doug hodder » Wed Feb 13, 2013 9:59 am
Looks great Dan! Is that quilted aluminum on the back splash an original or did you get that bent up? Did you also have to do any work on the liner on the ice box? Doug
Postby prohandyman » Wed Feb 13, 2013 3:41 pm
Not original just thought it would look nice since I am not actually restoring this unit. Ad yes the ice box was in bad shape so had a local sheet metal company make me a copy.
Dan
prohandyman
Images: 785
Postby doug hodder » Fri Feb 15, 2013 10:37 pm
It's a great looking galley! Nice job! Doug
Postby TRP » Mon Feb 18, 2013 11:38 am
The galley is a thing of beauty! I wish I had gone that route with my benroy. Love all of the aluminum!
Keep at it!
Ted
TRP
Images: 341
Postby prohandyman » Mon Feb 18, 2013 4:46 pm
Got some of the faux rivet work done today. Aluminum twist nails, driven in very tightly with silicone sealant. May add another row or two.
102285
Dan
prohandyman
Images: 785
