Hobbit Hole Build
Hobbit Hole Build
Postby Sammit » Thu Jun 20, 2013 3:41 pm
Hello all! I'm partway through my modified teardrop build. I've been pretty busy up till now, so I'm finally posting a journal. I'll load up all the pictures I have so far, then try to update as I go from now on.
My trailer uses the 4x8 HFT base and is going to look like a hobbit hole.
I have some experience in the carpentry/painting side of things, but the cabinetry and electrical are going to be my learning opportunities this build!
I don't know the etiquette for this sort of thing, so I'm going to add each picture as a reply with text to keep things neat.
First, here's a general example of the inspiration for the build:
Sammit
Re: Hobbit Hole Build
Postby Sammit » Thu Jun 20, 2013 3:43 pm
Starting out with the HFT kit. I was surprised how small the box was!
I debated moving the axle back, but I intend on having a woodpile and/or cooler on the tongue, so I figure the weight will nearly balance out.
Sammit
Postby Sammit » Thu Jun 20, 2013 3:44 pm
Wife and 16mo old helping bolt things together
Sammit
Postby Sammit » Thu Jun 20, 2013 3:45 pm
Base completed, no instructions from here on out!
Sammit
Postby Sammit » Thu Jun 20, 2013 3:46 pm
2x2 wood frame on top of metal frame
Sammit
Postby Sammit » Thu Jun 20, 2013 3:47 pm
I left a 3/4" ledge on the trailer to support the walls
Sammit
Wood frame attached to bed
Sammit
Postby Sammit » Thu Jun 20, 2013 3:48 pm
Coated bottom with Henry black asphalt emulsion
Sammit
Postby Sammit » Thu Jun 20, 2013 3:50 pm
First side wall up. I intended on making the profile more elliptical, but a plain half-circle worked best.
Sammit
Postby Sammit » Thu Jun 20, 2013 3:52 pm
Holy heck, measurements worked the first time, walls are flush with trailer sides!
I opted for a 3/4" side wall because I don't need a lot of insulation, so I decided to screw instead of bolt in the wall. Eventually both walls will be bolted at least twice, and trim pieces will cover the screw heads.
Sammit
Postby Sammit » Thu Jun 20, 2013 3:55 pm
Second side wall up. You can see the smaller round window in the front. I plan on making this work like a shutter with a permanent screen.
Sammit
Postby Sammit » Thu Jun 20, 2013 3:56 pm
Framing is up for the roof and galley wall with 1x2", and a double 2x2" for the hatch.
Roof is also framed for my Fantastic Fan (pictured) and a window in front.
Sammit
Postby Sammit » Thu Jun 20, 2013 4:05 pm
Filled out the galley wall, and built the hatch framing. It's currently clamped in to dry in the right shape.
Sammit
Postby Sammit » Thu Jun 20, 2013 4:07 pm
Inside of galley wall, bonus pic to show the author fits inside!
Sammit
Postby Sammit » Thu Jun 20, 2013 4:09 pm
The wife wanted the inside walls to look plastered/stucco-like, so I spent a couple hours with a putty knife and vinyl spackling.
Sammit
