Professor's Trout Wagon
Postby Professor » Thu Jul 18, 2013 4:15 am
My Trout Wagon is well under way and its time to share
109981
2x2 11 Gauge steel frame
109982
Gray and fresh water tanks that are 3 inch PVC
109984
Camper Box 1x1 16 Gauge Steel
109985
Fenders
109986
Air Conditioner in bulkhead wall. This was a tough choice.
109987
1 inch foam insulation. Box frame primed. Electrical run and checked. Wood supports installed for fixtures. Interior Birch installed. Tongue and grove Cedar floor installed
Professor
Images: 15
Re: Professor's Trout Wagon
Postby wert_david » Thu Jul 18, 2013 10:15 am
Looking good! I like the pvc pipe liquid storage idea - I am so stealing it! (I think 3" pipes will fit neatly in a couple of runs of long narrow spaces in my camper!)
wert_david
Postby Professor » Thu Jul 18, 2013 12:28 pm
Steal away! I certainly have. :D
Professor
Images: 15
Postby Professor » Thu Jul 18, 2013 12:33 pm
109993
109992
Two shots after I finished the exterior skin
Professor
Images: 15
Postby Ron Dickey » Mon Jul 22, 2013 9:41 pm
Do you plan to have a special compartment for the fishing polls. or are you putting pvc pipes on top you could run them in the upper corners inside the trailer and pull them out the galley. You know that place where you cook the fish. :D
Looks like a simple project nice window. you may want to put a curved bonnet or tung box with a curve at the top (not hard to do) at the front like I did on the boxkite. Found when you pull even though the pull unit should help reduce that the wind still flows around and gets caught by the flat front.
Here is one on a Camp Inn 58001 you just have to be careful you do not over load it. some folks put the battery up there and vent it on the sides.
Ron
173882......173887
Ron Dickey
Images: 787
Postby Professor » Wed Sep 18, 2013 4:28 pm
Actually, I will likely add a roof rack with 4"PVC attached on either side for my long fly rods. But you know, I gotta catch a fish to cook one :worship:
I can't find a tongue box I like so I'll make one. I need it for storage, but like you suggest I also need it to split the wind. The battery will go in front of the tongue box in its own vented container.
Because I will be pulling it behind my Jeep Rubicon I have to add the obligatory High Lift jack on one side and an axe and shovel on the other side.
Professor
Images: 15
Postby Professor » Wed Nov 27, 2013 1:50 am
Summer got away from me and I had to pause while life happened, but Christmas holidays are right around the corner. Over the break I hope to finish the galley lid and start the siding. I intend on using aluminum siding.
QUESTION: What sealer should I use on the wood exterior before I contact cement the aluminum on forever? Any wisdom is greatly appreciated.
Thanks in advance!
Professor
Images: 15
Postby Professor » Wed Nov 27, 2013 11:52 am
Where I'm headed with the Trout Wagon
114728
114729
Professor
Images: 15
Postby Junkboy999 » Sun Dec 01, 2013 4:50 pm
Interesting idea for the water tanks. 8)
Junkboy999
Images: 52
