41ford - Tear Build
41ford - Tear Build
Postby 41ford » Tue Aug 13, 2013 12:01 am
Well I jumped off the fence and started cutting and grinding, or in other words getting my (5'x10' flat bed) trailer ready to build. :thumbsup:[/attachment]
8) Cut out side rail out for door, and took cross member out to install a 4" to 6" dropped floorall depends on overall final design. :thinking:
tear frame 3 (250x188).jpg (48.13 KiB) Viewed 1041 times
tear frame 9 (250x188).jpg (49.39 KiB) Viewed 1039 times
[/img]]A wink is as good as a nudge! Know what I mean!![/color]
41ford
Re: 41ford - Tear Build
Postby CMC » Tue Aug 13, 2013 9:29 am
Looks like a good start. What design are you looking at doing?
Curtis
Finally the build has started. Oversized Off-road Benroy (Military Themed)
CMC
Postby 41ford » Tue Aug 13, 2013 7:17 pm
Well leaning toward an over size teardrop, 5'W x 10'L x 5'5" Tall, then with the dropped floor, room to stand. :thumbsup:
41ford
Postby citylights » Tue Aug 13, 2013 7:33 pm
How is the trailer upper rail going to look or work with the side wall of the tear? I see you cut the door out, but what about the rest? Also rail with front and back curve on the tear?
I had a similar trailer and debated doing the same as you for added trailer strength, but ended up cutting it all down. My cut down trailer was really flimsy until I attached the new deck.
citylights
Postby 41ford » Wed Aug 14, 2013 2:17 pm
I'm not sure yet, I did box the dropped floor in with 2 1/2 x 2 1/2 x 3/16th angle flipped and welded to the underside of frame 2 1/2 x 2 1/2 angle making a boxjpg[/attachment]
boxed dropped floor
tear frame 010 (250x188).jpg (44.2 KiB) Viewed 951 times
pre- boxed
tear frame 9 (250x188).jpg (49.39 KiB) Viewed 951 times
.[attachment=1]tear frame 02 (250x188).
set- up
tear frame 02 (250x188).jpg (52.2 KiB) Viewed 951 times
41ford
Postby CMC » Thu Aug 15, 2013 10:43 pm
I too am doing a drop floor but I am using it as a basement. If you want you can look at the sketch up of it so far, it might help give you some ideas.
Here's the link: viewtopic.php?f=62&t=56948
Curtis
CMC
Postby 41ford » Fri Aug 16, 2013 9:46 pm
Like to see more when you git in to your build. :)
41ford
Postby rebapuck » Fri Aug 16, 2013 9:51 pm
Lookin' good.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
