by WeirdDogGuy » Mon Apr 28, 2014 1:56 am
Sure. Form follows function. The design was originally a little longer b/c the longest item was my windsurfer mast but I decided to house the mast in a piece of pvc pipe underneath the subframe so that allowed me to get the length down to 16 feet. I like my Soob since it gets 32 mpg and is 4wd but it couldn't pull a greased string out of a cat's behind so it has to be a foamie ie lightweight. Serendipidity ruled the rest of the design. I'm trying to build it out of "stuff" that I already have. The hinge on the swing axle will be offset 4 inches from the centerline of the long axis. I had to offset it in order to have the centerline of the tire track inline with the centerline of the long axis. It's just the way the geometry worked out with the VW axle. Because the mounting point of the swing arm is offset, it will always impart a torsional moment on the structure. The best cross section to resist torsion is circular, but, oddly, I didn't have enough of the correct size round stock to use for the subframe. I do have a lot of 2-1/2 inch galvanized square tubing (14 ga) and that's the next best thing to resist torsion that I have available. But this will be a stressed skin structure so really, the fiberglass composite skin of the body will be working in conjunction with the subframe to carry the loading. So the body is a big torque tube in bending. Most (but not all) modern cars are built this way. The body is a space frame/truss with a smaller/lighter subframe assembly so really, this is nothing new. I'm using homemade casein as a resin for my composite. I started a thread in the foamie subforum about using casein and fiberglass as a composite material. It's common for foamie builders to use titebond+canvas as a composite. I've been experimenting with casein+Tyvek as the fabric but it's pretty lightweight stuff-1.85 oz/yard-and I'm not particularly impressed with its strength. I can tear Tyvek with my fingers. I have some other leftover fabric from a couple of years ago. I think it's 6 oz Xynole or some similar polyester fabric.Not sure, I'll have to check my records. Not sure yet which fabric I'll use, hemp is in the running, but I have decided on DIY casein as the resin. I'm also considering using more than one layer of fabric. That way I can orient the weft and the weave to its greatest potential. So for torsion, I'd lay the first layer of fabric 45 degrees to the long axis, then the second skin would be parallel to the long axis. I'm still welding the subframe so I have plenty of time to stew of this as I am not close to glassing yet. Two heads are better than one and I'd be happy to hear your ideas. Thx.Andy
