Oh, and I did scrub the idea of making the trailer able to pull behind my bike. At least this one... LOL
2/26/14: Well, I finally got a chance to get down to Harbor Freight in Kennesaw, Ga to get my trailer, I had first went to the HF in Douglassville, however, they were sold out of the trailer I wanted. Since I am attempting to build this small and light enough to haul behind my bike, {An 88 C.I. 2000 Harley Davidson Electra Glide} I was first going to use the small trailer that Harbor Freight has Model 2174, a 40.5” X 48” light duty trailer, however they did have one of these on display, and after seeing it up close and personal, I decided that it would not be big enough even with building my frame and floor larger than the trailer frame and getting a larger axel. So I opted for the Model 1169 48” X 96” trailer, I am still going to attempt to keep the trailer as light as possible but if it is too heavy to haul behind the bike, then I guess I am stuck with the truck till I can figure something else out. With the rain, the idiots on the road and having to get up an hour early due to the supervisor meeting, that is about as far as I got with it today. Hopeing that we are not working this weekend so that I can at least get the trailer assembled and plumed. Then I can start working on the sub flooring and floor frame.
3/10/14: Well, I got off my sorry butt and did some work on it this weekend. Had a nice weekend and we even had some time off. I got the basic part of the frame for the trailer built and started looking at getting the mounts for the spring perches put in. Problem is, I remember reading on the tear drop message board about shifting the axles, So I stop and start looking at where this is on the web site. Took a while but found it, then got to thinking about this, Is this really going to be needed, I look at a few of the trailers on the site and notice that NOT ALL of the trailers have the axles shifted! So I posed a question about this and one of the wiser individuals informed me that it is really not needed. The best bet is to build the trailer THEN see if you have a weight distribution issue or if there is a door clearance issue. Then you would know if shifting the axles is needed. However the rule of thumb as it is written on the site is 43 ½” from the back of the trailer if the axle needs to be moved.
Guess that tomorrow I can go ahead and put the spring perches on and go from there with getting the axle in the stock location, I guess that I will need to make my way to Snellville this weekend and get my Welder as well as some of my wood tools out of storage so that I can get the trailer fixed the way it needs to be done. I will have to make a 220 extension cord to run from the dryer out to the outside in order to get the frame squared and welded. Then I can move on to getting the sub floor in place.
5/19/14: Been a while since I have worked on the trailer. Been busy at work not to mention that I get pre occupied with other things when I was off, however to get this thing going, I had to get my butt in gear. Here we are in to Spring, almost summer and I have nothing but a bare metal frame in the back yard.
I tried to start on the frame last week, but found that my old welder had pretty much given up the ghost 10 years of Motorcycles, Trucks and other odd projects takes its toll on a B grade welder, But had to make an emergency trip down to Harbor freight and buy a fair Chicago Electric welder to replace the old one. Not top of the line, but for the welding that I do, I will work.
I ground down the areas where the cross members are on the trailer and with them checked to be square, I welded in place so that I don’t have to rely on the bolts only for any of them. Then will be welding the tongue in place so I don’t have to rely on the hinge bolts and the pin that Harbor Freight provides with their trailer. One note here, The Harbor Freight trailers are made of very soft steel so the power setting on the welder needs to be LOW. If not, you will just punch holes and chase your tail. One other thing work your bead fast and go heavy over your bead to push material which is already laid down to prevent losing a lot of trailer material.
Tomorrow I will also flip the trailer over with the aid of my Girl Friend to be able to weld the other side of the cross members, When I have it flipped upside down, I will take this time to square the front half to the back half and weld an angle piece over the gap in order to stiffen the entire frame in to one piece. Before setting the sub floor in.
One thing I want to say is I am truly thankful that my Girl friend is on board with this trailer. She has come up with some ideas for the Galley, Interior and even how to finish the exterior that I think will work better than what I was thinking. She is excited to see the trailer complete and getting to go camping in it. The more she is driven on the trailer drives me. So yes, this is going to be a good together project for us.
