I bought the Harbor Freight non-folding heavy-duty trailer while it was on sale plus the 25%off coupon. I used the savings to buy a spare tire and bearings.
NOTE: If you go to HF and buy a trailer and a spare tire it might save time and hassle if the cashier rings up the trailer first. They must enter DOT numbers into the system at the time they ring it up and the spare tire had numbers on it as well. If they ring up the tire first it throws a wrench in their system and prevented them from entering the DOT info for the trailer itself. They were going to leave it at that and only put the tire numbers in. I had them canel the entire transaction and start over with the trailer first so that its numbers were the ones in the system.
As for the china trailer itself: I wouldn't use it for a utility trailer that will see any kind of regular use, anymore more than a few times a year. The center tongue reinforcement that I put in did stiffen the entire front half pretty significantly. I'm sure that once a cabin is constructed it will tie it all together well, but as a flatbed utility trailer for a lawn service or something, no way would I use it.
My design is a 5.5' wide by 9' long built on the 4x8 trailer. The cabin will hangover each side about 9" and 1' at the back. I ended up doing pretty much all of the well-known mods to the trailer frame. I used the Excel spreadsheet to estimate tongue weight (and later verified with a real-world simulation by weighting the trailer for another purpose). The axle was moved 10.5" rearward and underslung, shocks were fitted, the center crossmembers were relocated as side-rail stiffeners, a piece of Unistrut was used to replace the center xmembers (unistrut might be a very underutilized material by builders), the tongue was stiffened and lengthened by a foot with a 2" tube and angle irons to the first two xmembers, the tilt feature was disabled and shimmed tight, and fold down stabilizer jacks were added to each corner. When assembling the trailer I found it very useful to use a ratchet strap at each crossmember to pull them in tight to the side rails.
The following picture shows a rear stabilizer. I'm trying a removable setup for the front stabs. The only way to easily mount them at the front corners results in them deploying in a direction that I didn't want. I used two short pieces of unistrut mounted to the frame and bolts and washers mounted in the stabs that slide into the unistrut.
NOTE: This type of jack has a little tab that protrudes on the inside edge. If you mount the jack directly up flat to your trailer frame that little tab sticks up higher than the rest of the jack and digs into the frame when the jack is folded up. I shimmed the jacks down some to provide clearance.
The next picture is of the shock mount. The top is angle bolted to the frame and the bottom is angle bolted to the u-bolt plate.
