5'x8' teardrop
5'x8' teardrop
Postby ericm555 » Sat Aug 23, 2014 7:31 pm
The base
The sides I cut with a jig saw. I traced them out with a string till it looked right.
The bottom has rubber glued to it.
1/8" plywood glued and screwed to the 3/4" side plywood.
headliner glued for the inside.
shelf and back wall installed
bending the roof with headliner on
started the trailer with a 2100 lbs torsion axle
finished trailer with primer
trailer with paint
metal on, I cut most of it with a double cutter
Rubber glued up the sides, primed so ice and water shield sealed to it.
I have more but that is enough for now.
ericm555
Images: 19
Re: 5'x8' teardrop
Postby steve cowan » Sun Aug 24, 2014 6:10 am
Great job you are doing,looking really nice! :applause:
Steve.
steve cowan
Images: 207
Re: 5'x8' teardrop
Postby flbikejunkie » Sun Aug 24, 2014 6:45 am
Nice job, like the shape!
flbikejunkie
Images: 134
Re: 5'x8' teardrop
Postby Woodbutcher » Sun Aug 24, 2014 9:14 am
Well done, it looks great! :applause:
Woodbutcher
