So this weekend I was able to get the rear bulkhead frame built as well as the front frame. I decided to build these as they add some rigidity and strength for the walls as well as the interior and exterior roof/ ceiling. These will also help make sure my walls are at a right angle and plumb with the floor as well as support the walls while I work on the stringers.
These were built from 2x4s that were ripped in half with a table saw. Lesson learned: measure very carefully when ripping boards in half. I was off by about 1/16" and it was very apparent. These will be screwed/ glued to the sub-floor. My walls will then be screwed into these frames.
The one wall in this pic is actually my template for 3/4" walls which will hopefully be built this coming week. I placed it here just to check on placement.
