Aussie Off Roader
Aussie Off Roader
Postby Wolfgang » Mon Sep 01, 2014 8:11 pm
I've been lurking on this site for a few months as I've been building my trailer. I liked the shape of the "Sawtooth" so based mine on that. All my trips are to the high country chasing Deer, so needed something that could handle and have enough ground clearance for the rough stuff. I've spent 20 odd years in swags and the last few in a roof top tent.... but I'm after a bit more comfort these days - starting to feel the cold :)
Some of the creature comforts I've included in mine are, full 12v power throughout with 120AH AGM battery, 100w solar panel, LED lights throughout (internal downlights and reading lights, external light bars on either side and kitchen, 21" LED TV, radio, gas instant hot water system, 2 burner gas cook top, 80 litre water tank and pump…. And I’m sure there will be more by the time I’m finished…
123808
123809
123810
I put in a false floor to raise the water tank partly into the trailer frame and for extra storage space.
Wolfgang
Images: 41
Re: Aussie Off Roader
Postby Wolfgang » Mon Sep 01, 2014 8:12 pm
123811
basic frame work
123812
3mm ply for internal cladding
123813
Wolfgang
Images: 41
Postby Wolfgang » Mon Sep 01, 2014 8:15 pm
123814
Rear kitchen area, cupboards and draws on the left, cooktop will be mounted on the right with the hotwater system mounted on the wall
123815
internal cupboards, TV will be mounted on the centre cupboard door
Wolfgang
Images: 41
Postby Wolfgang » Mon Sep 01, 2014 8:17 pm
123816
123817
All the wiring has been run through the walls and insulation installed, now the external cladding, 4mm Aluminium composite panel.
Wolfgang
Images: 41
Postby StockCube » Sat Sep 06, 2014 2:59 pm
Wow, looking good - you are off to quite a start. How long has it taken you to get to this stage?
StockCube
Postby Wolfgang » Sat Sep 06, 2014 11:00 pm
It's been about 5 months of playing around on weekends.. more progress this weekend will post photos later.
Wolfgang
Images: 41
Postby rebapuck » Sun Sep 07, 2014 1:45 am
You will be the envy of your off-road buddies.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby kd8cgo » Sun Sep 07, 2014 3:03 am
Lookin' good so far!
What's a "swag" some kind of tent? Are they drop bear proof? Needs a strong roof for those suckers.
kd8cgo
Images: 21
Postby Wolfgang » Sun Sep 07, 2014 8:08 pm
124020
door frame trim and internal timber trim to mount the seals on.
Wolfgang
Images: 41
Postby Wolfgang » Sun Sep 07, 2014 8:11 pm
124019
80litre water tank fitted..... have some issues with the filler mounting, because the tank is fitted so high inside the trailer frame I can mount the filler in the mudguard!!! Didn't plan that very well..... will now mount it in the side wall and run the hose down the back wall of the cabin... wont get in the way, just wont look as clean as I had planned.
Wolfgang
Images: 41
Postby Wolfgang » Sun Sep 07, 2014 8:14 pm
124021
Stainless Steel splash backs and bench tops going in the kitchen area.... still has the plastic covering on the stainless..
Wolfgang
Images: 41
Postby PaulC » Mon Sep 08, 2014 4:33 am
kd8cgo wrote:Lookin' good so far!
http://www.wildearth.com.au/shop/camping-gear/swags/1203
Have a look there
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Wolfgang » Mon Sep 08, 2014 5:16 pm
Beat me to it!! If you haven't slept in a swag you haven't been in the Aussie Bush! It's basically an improvement on the Drovers bed roll (Jackaroo, Cowboy)
Wolfgang
Images: 41
Postby Wolfgang » Mon Sep 08, 2014 5:42 pm
124058
this is the Canine version....
Wolfgang
Images: 41
Postby kd8cgo » Tue Sep 09, 2014 3:09 am
The smallest tent I have slept in was the US Army Shelter halves... I hated those things, they were heavy for what they were and split between two guys. Took up a lot of room in the ruck as well. I think these swags might be a better deal! I know I like the dome tents better than that old heavy stuff for sure. The Marines got some nice looking dome tents made by Eureka that were way cooler than our stuff!
kd8cgo
Images: 21
