Sealing home made door.
Postby albion2 » Thu Sep 25, 2014 11:21 pm
I just finished cutting out the door from the plywood sides,How did you guys managed to seal your home made doors on the out side, on the hinge side.
albion2
Re: Sealing home made door.
Postby jeporter25 » Fri Sep 26, 2014 12:24 am
That depends on the hinge. I used a Fridge style hinge and attached the T molding to all sides of the door. the seal was attached to the T molding. For a piano hinge you would need to either have some sort of offset so that a seal could fit inside of the hinge or you would have to wrap the outside of the hinge with rubber.
jeporter25
Postby albion2 » Sun Sep 28, 2014 2:06 am
Thanks for the ideas
albion2
Postby rowerwet » Sun Sep 28, 2014 5:24 pm
I put a frame ring on the inside for the door to seal against, I believe the link is in my signature
rowerwet
Images: 521
