The tiny teardrop
The tiny teardrop
Postby Sam_1688 » Sat Mar 07, 2015 5:07 pm
Well after looking at these for a few years I have decided to build a nice small one to pull behind the mk1 fiesta for our wee trips away.
We are going to attempt to make it as small as possible withing it feeling cramped.
The frame will be 3mm thick 50mm box section and ordered it from a local blacksmith as they were more than half the price than online..
Also I have ordered avonride suspension units, 10" wheels and tyres, hitch, jockey wheel and lights with 7 core cable.
That leaves my plan for the body, I'm thinking of 50mm styrofoam with 4mm plywood on the inside and exterior coated with fibreglass.
The only thing I haven't agreed on is the drawbar, I'm thinking a straight drawbar but will do some more research before I agree on it
Hopfully get started asap but will keep updated but really looking forward to getting it built and using it :D
Sam_1688
Re: The tiny teardrop
Postby pchast » Sat Mar 07, 2015 9:58 pm
Sam,
If you are considering small, I really recommend the refrigerator box
testing procedure. Mock up your proposed cabin in cardboard and take
a nap in it. Its much easier to alter that mock-up than rebuilding your
tear. It'll give you a good chance to decide on windows and possible
necessary skylight.
pchast
Images: 97
Postby felixx » Sat Mar 07, 2015 10:22 pm
Im making an 8x4 to tow behind my Anglia 105e
Welcome to the forum, there are few of us on here with old british cars :beer:
felixx
Images: 22
Postby Sheddie » Fri Mar 20, 2015 11:18 pm
Hi Sam welcome from another Mini fan from the other side of the world.
Good luck with your build. The scratch build for your frame is good, you can often find it quicker, easier and in the long run cheaper than modifying something else.
With your draw bar, if you are tossing up between a single pole or "A" frame and using the 50x50, a piont to consider. My general purpose trailer has a single 75x75, and some times it gets a funny little wobble to it, which feels like the draw bar flexing sideways. I could probably cure it with a light brace each side, but so far hasn't been too much of a problem.
Sheddie
Images: 1129
