http://s1382.photobucket.com/user/bc555 ... op%20Build
Specs:
-4x7 ft
-Built on a modified folding HF trailer
-1/2 inch birch plywood sides and floor.
-Rubber EPDM roofing on top of 1/8 inch plywood
-Basic indoor and outdoor LED lighting powered by a 7Ah gel cell battery and portable solar panel
-1 door (single most expensive part of this build! I plan to add another door soon)
I also added 120V power access with a 15 amp power strip and an RV power inlet for plugging in the battery charger or a heater. We shortened the trailer to 7 ft and were originally going to design a galley with a flip up table similar to the Little Guy Deuce galley, but decided not to halfway through the build since we could just pack a folding table and keep the cooking out of the teardrop. It also helps to save weight! I estimate our build to be around 500 -600 lbs empty but will get it weighed soon.
