Newbie here just started my first build. I started with a few napkin designs and landed on a 10'x6' standy on top of a 4x8 utility trailer I made in high school. Here is the first set of pics along with the journal entries that I am posting all at the same time because I am a slacker...it is all 2x4 construction which I know is heavy but I wanted it a little heavier due to the large side profile (wind) while towing.
First steps were the floor frame. I started with the fenders forward, then built a matching piece for the back.
April 11th 2015
note: The underside exterior plywood (1/2") was added to each piece of the floor frame as it was made which I regretted at first, due to all the weakest seams lining up, but it made a lot of the build much easier.
I then finished the rest of the floor framing.
April 20th 2015
The underside was sealed with caulk and painted with 6 coats of latex based extreior paint I found on a clearance aisle as it was mixed incorrectly.
