tawright915 wrote:1. I want to set up my build so that I can run off or battery or shore line out of the same receptacles. (I was thinking of coming into the camper from shore line to a battery charger, to batteries, to an inverter to the receptacles) Looking through the electrical forum, I am not sure I see a definite way to do this. Can someone point me to a post that would have a diagram showing how this is set up?
KCStudly wrote:The reason most people don't take their 120v exclusively from an inverter when shore power is available is because it is inefficient. Also, trickle style battery chargers don't typically have enough oomph to keep up with a high demand on a 12v system while under load.
Is it a mechanical parking brake or regular electric drums? If the later, you may want to check the regulations in your area about trailer brakes. I know that in my state (CT) if a trailer is equipped with brakes they must be functioning to be legal.
azgreg wrote:Can you post a link to your YouTube channel?
Vedette wrote:
