The V2 - complete build
Postby BigRay » Sat Aug 26, 2017 6:15 pm
It's time for me to post our build. Every summer we go somewhere new but staying in hotels has gotten a little old and I wanted a camper so we could expand our summer vacation options before the kids move out. We do frequent the texas coast so it must handle the harsh conditions. We tent camp a bit in cooler weather so anything I build can carry those supplies when needed. So I wanted it garageable, pop-up standy, aerodynamic, sleeps about 5, with a tiny bathroom, kitchen and a/c for starters. I initially bought a donor '68 shasta but soon discovered the frame was very heavy and the frame layout was all wrong so I sold it and went for the HF 1720 capacity. Off we go...
150667
carefully squared frame and use new high grade nuts & bolts then welded.
150668
built out to 6x12-ish and added shim sticks to make frame level.
150669
painted frame
150670
3/4"floor. we trimmed to fit the lay-flat sheet flooring but still don't use it.
150671
before painting underneath
150672
the leftover exterior gingerbread paint was thick as mayonnaise.
150673
messy spray foam kit purchased online. main purpose was to seal where the metal meets the wood.
150674
testing removing tire if I get a flat.
150675
this was later water-proofed.
150676
no shortage of TB3 and pocket screws. used levels and strings and square to keep squared up.
150677
looking forward
150678
150679
150680
rear view
150681
slides in for travel
150682
1/4" ply for exterior
150684
front door and yes it is very small.
150683
back shelves and door
150685
150686
150687
measuring for kitchen shelves.
150688
150689
driver side. note the hinged kick-out for more bed length. I ended up removing the hinges and covering it all. I plan on completing this later with a different design.
150690
outside back door.
150691
inside back door
150692
door skinned.
150693
150694
that is the side door frame on the right.
150695
the bottom right cut out is for the power center.
150696
side door skinned and adding trim.
150697
for the outside.
150698
150699
kids choice for the inside.
150700
every plywood edge has to be routed down smooth, at an angle
150701
150702
what it takes to make the door handle fit snug.
150703
gotta recheck for areas I missed.
150704
added trim to the back door.
150705
painted and closed in license plate area.
150706
finished trim.
150707
kick-out area. I am standing on bed area, 2 side by side. one is higher above wheel wells.
150708
very small area for jack, temp and eventually will be metal.
150709
mount for tail light.
150710
more painting.
150711
to keep plywood from warping. I could have gone with smaller trim.
150712
at nose, ran thru pvc to keep it simple.
150713
testing an idea I had. It worked very good.
150714
working on front marker lights
150715
I chose pneumatic door closers after some spring ones were to bothersome.
150716
150717
running license light.
150718
needs a temporary roof for an overnight camp test.
150720
fits easily without a permanent roof.
150721
temporary roof.
150722
didn't budge while traveling but I know it wasn't waterproof along the edges.
150726
on the camp trip at buc-ee's. :)
150728
the higher bed is on two wheel well benches and a table.
150729
thinking...
150734
yosemite trip is getting closer and the pop-up roof must get done.
150735
skinned both sides with luan.
150736
150737
camper inside is also luan.
150738
150739
steep roof, can not open tall side in garage.
150740
testing sheet bunk.
150741
this upper v-design is not exactly what i wanted but time did not allow for full box build.
150742
at least one end box will be similar to the hard-side vintage apache beds. crazy plan for sure.
150743
second sheet bunk finished. these work very good and can be slid out of the way. these were made for when the roof is down. sleeps 4.
BigRay
Images: 118
Re: The V2 - complete build
Postby BigRay » Sun Aug 27, 2017 8:44 am
150744
trying to figure what hinges to use for attaching v-panels. ended up going with large piano hinges.
150745
150746
150747
hidden ventilation behind license plate.
150748
fitting a slide panel to control air flow.
150749
closed 72 in, opened the width is now 74.5 in, this is where I am trying to commit to a roof design for our very long road trip.
150750
v-panels weight- tall 12 lbs each, short 9.8 lbs each
150751
upper walls weight- short driver side 31.8 lbs, tall passenger side 42.6 lbs.
150752
testing tarp as roof.
150753
lots of little details to do.
more coming soon.
BigRay
Images: 118
Postby BigRay » Sun Aug 27, 2017 8:57 am
My gallery images look like crud when they pop up in Tapatalk. What am I doing wrong?
Sent from my MotoG3 using Tapatalk
BigRay
Images: 118
Postby QueticoBill » Sun Aug 27, 2017 9:27 am
I see them all just fine on my desk top. Its an impressive build. Is current/final weight really under the HF trailer rating? I like The poor man's stabilizers (abbreviating that did not work). I was wondering how you enclose your feet/keep insects out with foot kick out.
QB
QueticoBill
Images: 22
Postby BigRay » Sun Aug 27, 2017 12:06 pm
Thanks. I took it to the certified scales and it weighed 1017 lbs. that was before the upper wall weights listed above which totals about 130 lbs. 300 lbs for equipment, supplies, food, luggage and all the unnecessary items everyone brought on our big road trip.
1017 + 130 + 300 = 1447.
The stabilizers worked better than expected. They were solid, not a bit of movement. Initially used bungies to secure for travel but it was difficult to mess with so I switched to 4 in. long pocket screws.
I am the tallest at 5'10", and since I sleep a bit fetal I fit fine. The plan for the kick out is hard wall like the camper. Thinking luan with thin insulation and it will look a bit like a small dog house hanging on the side.
Also planning a permanent hinged table along the passenger side.
BigRay
Images: 118
Postby featherliteCT1 » Sun Aug 27, 2017 2:29 pm
Photos look good to me ... nice work!
featherliteCT1
Postby BigRay » Mon Aug 28, 2017 9:05 am
Thanks
150754
using temp roof tarp as a template for white double layer tarp.
150755
adding lots of 1/2" grommets.
150756
what it looks like ready for travel.
150757
and what it looks like setup for use.
150758
plenty of natural light.
150759
150760
Yosemite. two thousand miles and a lot of wind separated a factory seam on the tarp so we took it off. Had to use ratchet straps to hold down panels.
150761
girls setting up camper roof. we did patch the seam with industrial duct tape which held good the rest of the trip.
150762
our campsite with tent for whatever.
150764
couldn't get a good photo while driving but the tarp balloons up at the rear. will have a new design soon.
I plan on getting some better inside photos.
BigRay
Images: 118
Postby featherliteCT1 » Mon Aug 28, 2017 9:22 am
I bet your kids will never forget this vacation and will look back for years with many, many fond memories. The trips I remember the most about are the ones when some kind of adversity was overcome by ingenuity... especially when the outcome was good. Great saves on the torn tarp and the loose panels!
featherliteCT1
