New with finished build, for now.
Postby Simple_Abound » Thu Feb 03, 2022 10:25 am
The family has affectingly named it Duck, Duck, Gray Duck.
168243168240168237168238168233168231168229
Simple_Abound
Images: 71
Re: New with finished build, for now.
Postby edgeau » Thu Feb 03, 2022 4:48 pm
Clever pop up design. How do you lift and lock it in place?
edgeau
Postby Simple_Abound » Thu Feb 03, 2022 8:02 pm
It's lifted with a long ram hydraulic jack. Once lifted it's supported with 6 3x3 posts secured with hasps which also secure it when down.
168259168258168257
Simple_Abound
Images: 71
Postby iggy3860 » Thu Feb 03, 2022 11:18 pm
Interesting design. Any links to the plans would be appreciated...unless of course this is a one-of design of your own :D
Iggy
[Ian McLaren]
iggy3860
Postby Simple_Abound » Thu Feb 10, 2022 8:37 pm
It is pretty much one off. It will never be commercially built, you have to know a few safety aspects when lowering and raising it. The post has 2 holes that gets raised and lowered with the jack. The travel on the jack is only 14" and the roof raises 21", the reason for the 2 holes. About halfway up and down I lock the post with a pin from traveling back down, also a good time to make sure nothing is getting destroyed. After it's raised I put the 6 posts up that are on hinges and lock them with the hasps. I tried to use a boat winch at first, it was disasterous I broke and bent everything on it. It's not that complicated of a design, I used mostly scrap wood and the jack which you can pick up almost anywhere. The whole design is too be able to pick up replacement pieces anywhere.
Simple_Abound
Images: 71
Postby Simple_Abound » Wed Nov 30, 2022 10:02 pm
I have put 2,500 on the camper and I've had no issues. I have made the bunks bigger, added another solar panel for a total of 300 watts and changed the bed and cabinets for the last time. I'm hoping to get 2 more years of use before my family has really outgrown the 40 square feet.
Simple_Abound
Images: 71
Postby Simple_Abound » Wed Nov 30, 2022 10:15 pm
170973170975170976170974
Simple_Abound
Images: 71
Postby Simple_Abound » Sun Dec 31, 2023 6:32 pm
I now have 5,000 miles on the camper. It has been demoted to the winter camper after the purchase of a Scamp. I officially weighed it, it's 1500 pounds unloaded. It weighs between 1700-1800 loaded. I installed a different tongue and another 100 amps of solar. I'm hoping to build a 5x8 benroy style next.
Simple_Abound
Images: 71
Users browsing this forum: No registered users and 23 guests
