Question - Canned Ham Frame
Canned Hams of all types and sizes...and Bread Boxes to go with that ham......
Postby BrandonWhite » Tue Dec 24, 2013 8:58 pm
Can someone please explain how someone gets curves like this for their frame? Is it similiar to the hatch on a teardrop?
BrandonWhite
Re: Question - Canned Ham Frame
Postby 48Rob » Wed Dec 25, 2013 6:53 pm
It can be done with plywood, by fitting sawn pieces of dimensional lumber together, or by laminating thin strips of wood together.
In your photo it appears that the frame was sawn from lumber and placed on a laminated strip.
The joinery is unclear overall. It may be two sets of pieces overlapping and screwed together, or it could be they used splines or lap joints.
Rob
48Rob
Postby Irmo Atomics » Thu Dec 26, 2013 5:57 am
I like cutting the curved framing and half lapping the joints.
115517
A lot of older campers have plywood strips veneered around the curve and some just have short blocks scrapped in along the curve. A lot of the wood seems to be there just for nailing because the structure of the camper is carried by the interior sheeting, cabinets, outer skin... it's more of a composite structure.
Bob
Irmo Atomics
Images: 64
Postby angib » Thu Dec 26, 2013 11:13 am
Yep, it's important to recognise that a camper is not a house - the framing does not need to be self-supporting since all the strength is in the continuous plywood. The framing is just there to connect two bits of plywood together. If the framing can stand up on its own, like the photo above, it's overbuilt.
If you could get 20x40ft sheets of plywood, houses wouldn't need self-supporting framing either.
angib
5000 Club
5000 Club
Images: 231
Return to Canned Hams & Bread Loaves
