rjgimp wrote:Does that have surge brakes? The contraption on the tongue looks remarkably similar to the one on my 69 Steury popup.
Pmullen503 wrote:Interesting, how did they seal up the corners when the walls were up?
Greg M wrote:You’ve sure got your work cut out for you, but it looks like you’ve got things well in hand
trevize1138 wrote:Pmullen503 wrote:Interesting, how did they seal up the corners when the walls were up?
The front and rear walls have double-hinged corner pieces that sort of wrap around to the side walls. From the inside you flip down these two levers to secure them to the side walls:
https://i.imgur.com/jAsxwvU.jpg
Pmullen503 wrote:Thanks, I had a pop up with bad canvas I got for a song and was going to use fold down foam walls but never came up with a good way to seal the corners.
Quite a project. If you have access to some good woodworking tools (and skills) it shouldn't be too hard to reproduce the bad pieces. Does the motorized lift mechanism still work?
trevize1138 wrote:rjgimp wrote:Does that have surge brakes? The contraption on the tongue looks remarkably similar to the one on my 69 Steury popup.
No idea! This is why I'm posting here because of replies like this. People seeing stuff I hadn't even thought about.
Under that rectangular box behind the hitch there's some kind of hydraulic-looking lever. I've been wondering what that is. I'll have to look that up now. Thanks!
rjgimp wrote:Wow, this is nifty! Here is the operating manual from 1968. I presume things didn't change much mechanically over the ensuing three years.
http://www.popupcamperhistory.com/rolite1968manual.html#
rjgimp wrote:Here is the brochure for the 1971 Rolite lineup. It shows the available list of optional equipment. Looks like the 1500 model was equipped standard with surge brakes. The larger 1700 and 1900 had optional electric brakes.
http://www.popupcamperhistory.com/rolite1971brochure.html
Here is a price list from 1969. The model 1510 went for $2095 and you could even get air conditioning for an extra $279.95!![]()
http://www.popupcamperhistory.com/rolite1969pricelist.html
Lots of old ads and brochures and other fun stuff on that site
Return to Canned Hams & Bread Loaves
