HEY! My teardrop would be a super soaker water canon at teardrop gatherings!
It should get good solar gain for water heating.
Anybody done this before? Have a plan or sketch?
Olddog1 wrote:Just ran a little math on your idea.
6" x60" cylinder has a volume of 7.34396
7.34396 x 8.35, weight of 1 gal. of water = 61.32207 lbs. per cylinder x 2 = 122.64414 lbs. on the roof of your TD
Probably going to have an effect on your CG and how the TD tows.
rowerwet wrote:Saw a guy at the beach this year with a set up like you mentioned, large dia PVC mounted to the roof rack on his van, with a Y on the aft end the top of the y had a screw off cap for filling, the bottom of the y had a reducer to a brass ball valve, below that was a hose quick connect, the hose was off a camp shower bag with the nozzel on the end. He told me after a day in the sun the water was warm enough for him but not his wife. I suggested he paint the pipe black.
He said it was nice to wash off the salt after surfing.
H.A. wrote:PVC can be a great way to go.
One thing, (of course cheap is subjective,,,)
Unless you have access to useful scraps or surplus, Its not going to be cheap.
6" Sch 40 is about 10$ per foot and you might have to buy a 10 or 20' minimum. Its fittings, caps & whatnot start around 10-12$ each.
